maintenance required light on
Old Sep 7, 2002 | 06:51 AM
slowacura's Avatar
Default maintenance required light on
does that mean i just need an oil change or is something wrong?
Old Sep 7, 2002 | 07:16 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: maintenance required light on (inteGSR)
how many miles are on your car?
Old Sep 7, 2002 | 07:51 AM
slowacura's Avatar
Default Re: maintenance required light on (Hatchy-Ownzjo0)
48,xxx
Old Sep 7, 2002 | 07:57 AM
Tweakmeister's Avatar
okay this one is easy...
it's an automatic timer...it's not like the check engine light (which fires off based upon sensors).
when you are sitting in the driver seat, put your right hand under the dash right in front of you and feel up there for a button. Or...just look under the dash for the button, it's right there. With the key in the on position hold in the clutch and press the button until the light goes off (it's an oil change thing).
Old Sep 7, 2002 | 08:00 AM
Rory Breaker's Avatar
Default Re: maintenance required light on (Tweakmeister)
I just press it without doing anything...no clutch or on position, just start the car, when it lights up, hold the button down
Its a small square button kind of above the gas pedal, at the very bottom of the dash.
Old Sep 7, 2002 | 08:01 AM
slowacura's Avatar
thanks guys
[Modified by inteGSR, 5:01 PM 9/7/2002]
So FReSh
Oct 9, 2008 12:29 PM
20ls01
Mar 8, 2007 04:31 PM
WindingRoad
Oct 10, 2005 05:55 AM
1sikhatch
Jun 3, 2005 05:44 PM
riceking3
Jun 27, 2002 05:30 PM
