maintenance
on a 1997 gsr w/ 118k usually what should be replaced for maintenance?
-timing belt
-belt tensioner
-water pump
-thermostat?
-fan switch?
-spark plugs?
-fuel filter?
not sure about the ones with question mark.
-timing belt
-belt tensioner
-water pump
-thermostat?
-fan switch?
-spark plugs?
-fuel filter?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2rtek »</TD></TR><TR><TD CLASS="quote">on a 1997 gsr w/ 118k usually what should be replaced for maintenance?
-timing belt
-belt tensioner
-water pump
-thermostat?
-fan switch?
-spark plugs?
-fuel filter?
not sure about the ones with question mark.</TD></TR></TABLE>
replace the oil pump as well when you do the timing belt.
and may as well do the thermostat and the plugs... when was the last time you replaced these things?
there are sites that have the schedule, search on google I'm sure you'll find it in a matter of minutes
-timing belt
-belt tensioner
-water pump
-thermostat?
-fan switch?
-spark plugs?
-fuel filter?
