Main relay
Old Jul 14, 2006 | 07:56 PM
atg1290's Avatar
Default Main relay
Ok so i tore apart the itnerior to replace it with black and also add a feul cut off. I did not run the switch right and now im having problems. The car cranks but i dont hear fuel pump or anything. Also i checked all the fuses and wiring after replacing the dash, the ac works and so do all my lights but my cluster doesnt light up when i turn the key and also no clock or windows. I think it might be a main relay but i just took it out of the housing and all solder points seem strong?? I hope i didnt mess anything up bad.
Thanks for the help
Old Jul 14, 2006 | 08:02 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: Main relay (atg1290)
heres how to tell if its the main relay: when you turn the key to ON, the CEL will light up for 2 seconds, then turn off. right when it turns off you will hear the relay click. if you do not hear it click, then dont even bother trying to start the car; the fuel pump isnt getting juice. i couldnt hear the fuel pump in my DA, because of the obnoxious loud antenna motor. but on those hot days, where my interior was about 120 degrees, i knew my car wasnt gonna start, and i would turn the key and the relay wouldnt click, and then started the long, boring process of... sitting and waiting for the thing to work. expletive main relays; mine went bad 2 months after replacing it with a new one
Old Jul 14, 2006 | 08:09 PM
atg1290's Avatar
Yeah i forgot i dont hear any clicking like i am suppossed to and also NO lights at all in the cluster. You know how when you turn it twice all the light come on mine doesnt thats why im worried about why the ac works but not the clock or cluster or windows. Thanks for the fast reply!!
Old Jul 14, 2006 | 08:11 PM
Default Re: (atg1290)
i honestly dont know what to tell you about the lights. when my relays didnt feel like working, everything was perfectly normal except the fuel pump of course.
Old Jul 14, 2006 | 08:13 PM
atg1290's Avatar
SOB2@@?#w:@#e":2EWDLKSDAEFDDJ ,CF
Old Jul 14, 2006 | 09:08 PM
stepka001's Avatar
check the wiring for the igniton switch
Old Jul 14, 2006 | 09:18 PM
atg1290's Avatar
It has to be a main relay and damn im so stressed!
Old Jul 15, 2006 | 07:25 AM
stepka001's Avatar
The main relay only controlls the fuel injection
Old Jul 15, 2006 | 02:14 PM
atg1290's Avatar
it was the ignition jointssssss...
Old Jul 15, 2006 | 02:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atg1290 &raquo;</TD></TR><TR><TD CLASS="quote">it was the ignition jointssssss...</TD></TR></TABLE>
so your ignition "joint" made the fuel pump not work?
Old Jul 15, 2006 | 02:48 PM
atg1290's Avatar
Yeah the prongs were not lined up correctly also casuing elec. problems.
ckirso
Mar 18, 2013 08:08 AM
brandonDAvid
Feb 12, 2011 11:40 AM
JDM_FATBOY
13
Nov 12, 2007 07:33 AM
NazVil86
Oct 10, 2006 06:44 PM
mgries
Sep 19, 2002 07:15 PM
