Lumpy Idle...CEL...
Sometimes when I start my car, I get a really low, lumpy idle and the car almost wants to die. This doesn't happen very often at all. The other 95% of the time when I start my car, it starts up just fine and Idles normally.
The other night this happened, and the CEL came on for about 5 miles. I turned the car off and let it sit for a while, then started it up like 30 minutes later and it was just fine with NO CEL.
Anybody have any idea?
its a 1999 LS. Sorry but I don't know how to pull codes, I guess I'll search unless somebody wants to spoon feed it to me really quick.
Ok I think I figured it out. The CEL flashed 7 times slowly, then 4 times fast, so Im guessing Code 74
Which is random misfire on cylinder 4. #4 cylinder...dead? Idle is real shitty right now, and was hard to start..
Modified by dezerte at 11:53 PM 3/18/2007
Perform a compression check. Several things can cause this:
bent valve
poorly adjusted valves
bad spark plug
bad plug wire
bad distributor cap
bad distributor rotor
clogged fuel injector
etc.
BTW: the Integra forum faq thread has a link to a tutorial for CELs.
bent valve
bad spark plug
bad plug wire
bad distributor cap
etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">Perform a compression check. Several things can cause this:
bent valve
bad spark plug
bad plug wire
bad distributor cap
etc.
BTW: the Integra forum faq thread has a link to a tutorial for CELs.</TD></TR></TABLE>
Thanks a bunch, very helpful
bent valve
bad spark plug
bad plug wire
bad distributor cap
etc.
