lsvtec info?
Old May 9, 2004 | 10:21 PM
mrxracing's Avatar
Default lsvtec info?
i'm sure it's in a previous thred already but it is so much easier to just ask as long as i'm not attacked! but i'm waiting on my gsr head for my conversion i have a 95ls and need to know what else i need besides an ecu for the complete conversion?
thank you
Old May 9, 2004 | 10:31 PM
Sack Master's Avatar
Default Re: lsvtec info? (mrxracing)
You need a bit more then just a head and an ecu. Last I checked a head needs an intake manifold for starters. Just do a search. A ton of people have done it and showed what is required.
Old May 9, 2004 | 10:36 PM
mrxracing's Avatar
Default Re: lsvtec info? (Sack Master)
i know that much. like special head gaskets or gsr wire harness don't mean to be a nagg but i've tried to research and i can't find a whole lot!
Old May 9, 2004 | 10:44 PM
Well you'll have to run some wires, vtec, vtec pressure, knock sensor, and maybe a couple more. You'll use an LS head gasket. Run a gsr water pump, timing belt and oil pump. Your head has to be prepped properly for the conversion, you'll need all the line and fittings.. I would recommend at least running gs-r or b16 pistons in it. Trust me pistons help big time. Not only on H-T but if you look around the internet there is all the info you need to do this. It's not hard to do at all. Many people have done it including myself (4 years ago and that engine is still running strong lol). Good luck with it.
Old May 9, 2004 | 10:47 PM
mrxracing's Avatar
thank you
Old May 10, 2004 | 03:35 AM
nickgmiller04's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrxracing &raquo;</TD></TR><TR><TD CLASS="quote">i know that much. like special head gaskets or gsr wire harness don't mean to be a nagg but i've tried to research and i can't find a whole lot!</TD></TR></TABLE>
seriously?? hit the "archived" search button and search for "lsvtec" "ls/vtec"
http://www.hondaswap.com has a good article too
archived content and "lsvtec" returned 538 threads w/ lsvtec in the title
Old May 10, 2004 | 10:06 AM
xplanetearth420x's Avatar
Default Re: lsvtec info? (nickgmiller04)
this tells you everything you need to know
https://honda-tech.com/zerosearch
Old May 10, 2004 | 03:53 PM
99lsvtecauto's Avatar
Default Re: lsvtec info? (xplanetearth420x)
check out import review they have the best review with a list of parts and b16 heads cost less than gsr easier 2 find
Old May 10, 2004 | 05:57 PM
LSvtec03's Avatar
Default Re: lsvtec info? (99lsvtecauto)
https://honda-tech.com/zerothread?id=501372
Old May 12, 2004 | 07:21 PM
TurboxDC2's Avatar
i would suggest using the golden eagle conversion plate for your oil feed line....i made the mistake of not using it and i've changed my oil like 5 or 6 times so far with 2000 miles on the motor....Tom at camp1320 has them for $85 shipped...also cometic makes head gaskets that are specially designed for LSvtec.
SilverEK96
Jan 24, 2012 03:53 PM
kkeefedout
12
Aug 9, 2009 10:04 PM
spun13
Aug 22, 2007 10:40 AM
Sliced Beard
Jul 14, 2004 10:31 PM
BIntegra99
Jun 30, 2003 03:33 PM
