Ls/vtec head studs
Old Jul 15, 2008 | 07:19 PM
floridaboy56's Avatar
Default Ls/vtec head studs
im doin a ls vtec set up i have a stock ls block bored .25mm with jdm type r pistons. stock crank, stock rods, arp rod bolts, acura rings and bearings, , my question is can i reuse my head bolts or should i go with a set of arp head bolts, and if so do i order them for a ls block or the gsr block cause they list v-tec and non v-tec studs. Also do i use an ls, water pump, timing belt and seals or get the type r, or gsr parts. i work in parterner shipw ith acura so i can get oem parts cheap some one help me out.
Old Jul 15, 2008 | 11:27 PM
jturbo8316's Avatar
Default Re: Ls/vtec head studs (floridaboy56)
Go with some ARP head studs. Get the ones that will thread to your LS block but will fit the V-tech head. Just go on the ARP website you'll see what i mean they make an LS V-tech head stud. You have to use either the type r or gsr water pump i believe they have 22 teeth on them not sure but dont use the one that has 19 teeth go with the one that has more teeth, type r oil pump, gsr or type r timing belt and as far as the seals for the most part all the B blocks are prety much the same you can go with the LS ones.
Old Jul 15, 2008 | 11:35 PM
jturbo8316's Avatar
Default Re: Ls/vtec head studs (jturbo8316)
Any V-tech head gasket and the LS V-tech dowl pins forgot to mention those
Old Jul 16, 2008 | 01:41 AM
DVSBIZZYB's Avatar
Here is the part number for the ARP studs #208-4303. Its the GSR studs.
Here is the lsvtec thread
https://honda-tech.com/zerothread?id=1676914
Old Jul 16, 2008 | 03:24 AM
Default Re: Ls/vtec head studs (DVSBIZZYB)
the golden eagle ls vtec should come with the right dowl pins right??
Old Jul 16, 2008 | 04:16 AM
Mfoehrkolb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by floridaboy56 &raquo;</TD></TR><TR><TD CLASS="quote">the golden eagle ls vtec should come with the right dowl pins right??</TD></TR></TABLE>
--- Yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jturbo8316 &raquo;</TD></TR><TR><TD CLASS="quote">Any V-tech head gasket and the LS V-tech dowl pins forgot to mention those</TD></TR></TABLE>
--- Use the pins but you NEED to use a LS/b20 Headgasket. If you use a vtec gasket, you will have some leaks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by floridaboy56 &raquo;</TD></TR><TR><TD CLASS="quote">im doin a ls vtec set up i have a stock ls block bored .25mm with jdm type r pistons. stock crank, stock rods, arp rod bolts, acura rings and bearings, , my question is can i reuse my head bolts or should i go with a set of arp head bolts, and if so do i order them for a ls block or the gsr block cause they list v-tec and non v-tec studs. Also do i use an ls, water pump, timing belt and seals or get the type r, or gsr parts. i work in parterner shipw ith acura so i can get oem parts cheap some one help me out.</TD></TR></TABLE>
--- ARP Head studs for sure. In order to make a reliable LS.V set up. I would rec. buying the 8mm ARP Rod Bolts. It's a muster if you do it. Rod bolts on LS.V are the weakness in the builds.
Old Jul 16, 2008 | 03:04 PM
Default Re: Ls/vtec head studs (Mfoehrkolb)
will the 8mm rod bolts fit into the rod caps without any problem, or will i have to get the rod caps machined bigger to fit the new studs? also as far as the computer and wiring wat ecu do i need to get and what else to i need to do as far as electrical?
Old Jul 16, 2008 | 04:50 PM
Mfoehrkolb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by floridaboy56 &raquo;</TD></TR><TR><TD CLASS="quote">will the 8mm rod bolts fit into the rod caps without any problem, or will i have to get the rod caps machined bigger to fit the new studs? also as far as the computer and wiring wat ecu do i need to get and what else to i need to do as far as electrical?</TD></TR></TABLE>
--- You would need a Vtec ECU. P28 manual or gsr ecu. something like that. You would also need it to be OBD1 or lower to you can tune/chip it.
the 8mm bolts will fit fine, you will just need to torque them a couple times. to sit properly.
almostjdmeg
Jan 3, 2009 07:41 AM
BOOSTEDgreeneg
Feb 15, 2006 03:42 AM
tegasaurus
Jan 15, 2004 06:05 PM
Speed_Dreams
Jul 27, 2003 01:48 PM
7rrivera7
May 24, 2003 04:29 PM
