Ls/vtec or gsr engine
Old Feb 18, 2004 | 06:13 AM
shannon's Avatar
Default Ls/vtec or gsr engine
I was wondering which decision would be my best decision. I have an 96 RS with a B18B1 engine and I'm thinking between buying a gsr engine or do LS/vtec.which one do you guys recommend me to do and which one will be cheaper. Where I live I can get a gsr engine for like $1500-$2000 out of japan.
Old Feb 18, 2004 | 08:43 AM
rusteds2k's Avatar
Default Re: Ls/vtec or gsr engine (shannon)
I heard the ls/vtec is faster than the gsr and cost less to do. But I also heard it's not very reliable. my opinion is to go with the gsr or turbo that ls..(that's what i did)
Do more search on here to find out more info.
Old Feb 18, 2004 | 08:45 AM
91integraLSVTEC's Avatar
Default Re: Ls/vtec or gsr engine (xaznxboixsirx)
get a gsr swap if you can get it that cheap
Old Feb 18, 2004 | 08:46 AM
get a gsr engine if you can get it that cheap, all you need is the engine tranny and ecu should be less than 3 grand if you do the swap yourself
Old Feb 18, 2004 | 08:47 AM
Dyno Queen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xaznxboixsirx &raquo;</TD></TR><TR><TD CLASS="quote">I heard the ls/vtec is faster than the gsr and cost less to do. But I also heard it's not very reliable. my opinion is to go with the gsr or turbo that ls..(that's what i did)
Do more search on here to find out more info.</TD></TR></TABLE>
I have a few friends local here who have the LSvtec, and its very reliable, got the low end tq of the LS, and the mad pull on top end of the gsr, if i were u just get the vtec head get the golden eagle kit and do it. Just my .02!! good luck
Old Feb 18, 2004 | 08:58 AM
onefstek's Avatar
gsr
Old Feb 18, 2004 | 09:09 AM
DA-nteg's Avatar
Default Re: (98ctr)
ls/vtec
Old Feb 18, 2004 | 09:10 AM
Dyno Queen's Avatar
Default Re: (DA-nteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA-nteg &raquo;</TD></TR><TR><TD CLASS="quote">ls/vtec </TD></TR></TABLE>
Old Feb 18, 2004 | 09:15 AM
rusteds2k's Avatar
There are gonna be a lot of mix reviews. So your best bet is to Search for more info before you decide on anything.
Knowledge is Power.
Old Feb 18, 2004 | 09:17 AM
JDM_Risa's Avatar
Default Re: (Dyno Queen)
ls/vtec or gsr good question
i had lsvtec then i went to gsr one thing i can tell u i felt i was missing something......
torque and compression i had an ls/vtec with itr cams, usdm itr rods, gsr head milled .003 with dc sport 4-1
vs my gsr with stock bottom end mmilled .003 port and polishd and skunk stage 2 cams along with a DTR header
still till today i loved that extra torque ls/vtec is sick if built right
now i got all the torque in the world
Old Feb 18, 2004 | 09:39 AM
Dyno Queen's Avatar
Default Re: (GunMETAL_TEgRa)
got any vids of your 2.0 teg?
Old Feb 18, 2004 | 12:40 PM
shannon's Avatar
ttt
Old Feb 18, 2004 | 02:00 PM
DC4KiD's Avatar
If you can get a LS-V or CR-VTEC built right, go for that!
Old Feb 18, 2004 | 09:33 PM
sumyungguy's Avatar
gsr
if you think about it type r/gsr/b16 blocks were built to spin at high rpm's from honda. meaning they are balanced to factory tolerances. this is why stock type r's can spin above 9000rpm <U>safely</U> and gsr's to 9000 rpn. when you take a ls or b20 which stock are only good to spin a low 7500-8000 rpm safely. going above that puts stress on the block internals. most if not all people that go ls/b20 vtec spin to atleast a stock gsr rev limiter 8200. in my opinion type r or gsr. if your looking for torque make it with your cams (toda spec b's), bigger bore, or stroke it to a 1.9L or 2.0L.
Old Feb 18, 2004 | 09:38 PM
DC4n714's Avatar
ls/vtec
Old Feb 18, 2004 | 09:39 PM
ChillOutWayne's Avatar
gsr
Old Feb 18, 2004 | 09:44 PM
riceball777's Avatar
ls vtec if u know what your doing
Old Feb 19, 2004 | 04:22 PM
RidinStock's Avatar
ls/vtec with good machine shop work
Old Feb 19, 2004 | 04:52 PM
Kendall's Avatar
It depends upon how well built the LSVTEC is. Also, it's not likely that you'll find a complete GSR swap for that cheap. maybe a longblock and an ECU. I think that the best option is to not do anything and establish some goals. When you have done that, then research which option will best help you reach those goals, and then go through with the plan.
Old Feb 19, 2004 | 05:01 PM
integraGSR1's Avatar
GSR, i'm not too much of an LS/VTEC fan. i have friends that have them, but i still can beat them in my almost stock GSR. i guess it's how you build it up. i think the LS/VTEC is a fad for now and will be gone tomorrow.
Old Feb 19, 2004 | 05:04 PM
JojoBananas's Avatar
Default Re: (Kendall)
do the gsr. only do the ls vtec if you get some b16 pistons or itr or something with high compression or the car will feel like crap. I wouldnt do the ls/vtec though but thats just my opinion.
Old Feb 19, 2004 | 05:10 PM
yea 1500-2000 sounds about right, hit that up and skip the ls/vtec, ive heard too many horror stories on that.
Old Feb 19, 2004 | 05:20 PM
nissan sr20det's Avatar
Default Swapping b18b into 94 integra
will a 94 stock transmission fit a b18b? need to kno, so dont say anything if you think you know, i need someone to tell meif they know for sure, very important
Old Feb 19, 2004 | 05:23 PM
Dyno Queen's Avatar
Default Re: Swapping b18b into 94 integra (nissan sr20det)
all b series are the same, 88-91 is cable, 90-93 is cable 94-up is hydro
Old Feb 19, 2004 | 05:29 PM
J337_UNIT's Avatar
Default Re: Swapping b18b into 94 integra (Dyno Queen)
LS/VTEC motors have alot of potential however imo and from what i have seen, they tend to be un reliable for the most part. i have met a few locals with LS vtec set ups that were un reliable. IE went through a few head gaskets in less then 4 months..another kid had oil leaks all over the place.. dont get me wrong.. a good LSVTEC set up can be reliable if built right. But usually can cost a pretty penny. IMO would be better to stick with a gsr motor because of reliability issues, especially if you dont have the money to build a GOOD lsvtec set up.. just my 02 cents
