Ls vtec build question
Old Jan 4, 2013 | 02:38 AM
Eg.ls.turbo's Avatar
Default Ls vtec build question
Hey im new to the lsv build so I got a question. My setup is ls crank/rods with type r piston in a gsr block with stock head with super tech valve spring and retainers. Wanted to know if a fuel pressure regulator or injector upgrade is needed? Just lookin to get 200whp and I will add cams and cam gears etc later on
Thanks in advance
Old Jan 4, 2013 | 10:16 AM
mouab18c1's Avatar
Default Re: Ls vtec build question
Stock injectors can hold up to 200whp. So no need to upgrade now unless you have the money.
Old Jan 4, 2013 | 10:23 AM
stowne78's Avatar
I'm running 11 psi on a stock fuel pressure regulator....but I'm not sure at what point on NA builds it's recommended to upgrade.
Old Jan 4, 2013 | 04:38 PM
Ok cool how about fuel pressure regulator? Keep it stock on lsv?
Thanks again
Old Jan 4, 2013 | 09:22 PM
mouab18c1's Avatar
You can use your stock fuel pressure regulator.
Old Jan 5, 2013 | 04:06 AM
Awesome thank for the info man
Old Jan 5, 2013 | 05:10 PM
DirtyDA9's Avatar
As stated above you can use stock injectors or you can look into dsm 450's
Old Jan 5, 2013 | 05:39 PM
Got another question. Is ok to use stock gsr head bolts? I won't b racing it daily just once in awhile
Old Jan 5, 2013 | 09:24 PM
mouab18c1's Avatar
Depending on the mileage I would honestly invest in Arp head studs
Old Jan 5, 2013 | 10:13 PM
GagnarTheUnruly's Avatar
You gotta get new ones anyways so I'd just get Arp
Old Jan 6, 2013 | 10:55 AM
Ok thanks
Old Jan 6, 2013 | 11:24 AM
stocker2shocker91's Avatar
I requested a short story for a title.
i have arp on my lsv, its nice to have the added reasurrance
Old Jan 6, 2013 | 02:51 PM
Has anyone have trouble with the ls crank hitting the oil squirters in a gsr block? I've read a lot and some peeps say it only hits the the oil squirters stem and bends them out the way. But mine hits the oil squirters bolt and the squirters stem I know thers a plug kit but really wanted to use the oil squirters cause I don't have aftermarket pistons just oem type r pistons
Any suggestion????
Old Jan 9, 2013 | 01:04 AM
Anyone?
Old Jan 9, 2013 | 09:28 AM
Actually I was reading some threads last night and you might be safe reusing stock head bolts if you aren't planning on turbocharging or going really high compression.
Old Jan 9, 2013 | 09:35 AM
No boost. My compression will b only bout 10.8-9 its goin b my daily driver. U think the compression will b fine on stock head bolts? Also wanted to add I found one valve stem a lil bent on my gsr, I got a ls head cylinder Layin around and was wondering if the valve stem from the ls head work on my gsr head?
Old Jan 9, 2013 | 04:19 PM
Tttt
Old Jan 9, 2013 | 10:39 PM
Someone? Anybody help please?
Old Jan 10, 2013 | 07:13 AM
Based on the threads I was reading the other day, you'd be fine. It turns out that a lot of the experienced all-motor guys reuse their head bolts. If they are torqued correctly they should not stretch.
That said I'd replace them if 1) they required lots of extra torque to remove, 2) they are difficult to thread back in.
Old Jan 10, 2013 | 07:51 AM
Gotcha. What about valve stem, will the ls valve stem work in gsr head?
Old Jan 10, 2013 | 08:21 AM
I doubt it. I wouldn't skimp on the head. At least use GS-R valves. Did valves not come with the head? Also, why did you chose LS rods? Those are going to be your weakest link.
Edit: this thread may help you http://marketplace.honda-tech.com/sh...ghlight=shodan
Old Jan 10, 2013 | 08:44 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
FYI- A LS-vtec build consist of using a non vtec block and installing a vtec head. Your build is not technically a LSVtec. I would consider it more of a stroked GSR since you have increased the displacement using a LS crank in a GSR block and head.
Old Jan 10, 2013 | 08:46 AM
[/url]
He has to when using a LS crank. He would be better off with aftermarket LS rods but I imagine as long as he is NA, they will be ok.
Old Jan 10, 2013 | 03:30 PM
Yea valves came with the head, I took them out one by one and put them on a drill and rotated them to check for any bent valves and found two bent valves, one intake and one exahaust. Ill be sure to purchase new one just wanted to check cause I had an extra ls head Layin around that I wasn't using.
Old Jan 10, 2013 | 03:36 PM
Oh and using ls rods cause of a more torque. How much power can the ls rods hold? I'm not lookin to drag race just something to make close to 200whp, a lil street racing but still b my daily driver. And I don't want to rev it past 8500rpm stayin below that or maybe right at it.
