ls/vtec
Old Jul 14, 2008 | 05:20 PM
DuStIn[T.s.]'s Avatar
Default ls/vtec
tips?
Old Jul 14, 2008 | 05:34 PM
seldon's Avatar
Default Re: ls/vtec (DuStIn[T.s.])
here's a great tip..........SEARCH
Old Jul 14, 2008 | 06:55 PM
Da9Gro's Avatar
Default Re: ls/vtec (seldon)
hahaha.. jerk! could've been a lil more nice about it.. well go on g2ic and they have a step by step on the ls/v conversion
Old Jul 14, 2008 | 08:32 PM
Pat_S's Avatar
Default Re: ls/vtec (Da9Gro)
Not again. Please, listen to the guy above (seldon).
Old Jul 14, 2008 | 08:49 PM
geekypbmaniac's Avatar
Default Re: ls/vtec (Pat_S)
like everyone has stated. Search using google.
Keep in mind that even if you put a Vtec head on, and dont touch the bottom end of your motor, your redline is the same as the LS Motor. The LS motor will die on you as the GSR bottom end is a tad bit stronger and can rev higher for vtec, while the LS bottom end can not.
Old Jul 14, 2008 | 08:56 PM
J. Funk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DuStIn[T.s. &raquo;</TD></TR><TR><TD CLASS="quote">tips?</TD></TR></TABLE>
search you idiot
Old Jul 14, 2008 | 10:53 PM
dayvid05's Avatar
Default Re: ls/vtec (geekypbmaniac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geekypbmaniac &raquo;</TD></TR><TR><TD CLASS="quote">like everyone has stated. Search using google.
Keep in mind that even if you put a Vtec head on, and dont touch the bottom end of your motor, your redline is the same as the LS Motor. The LS motor will die on you as the GSR bottom end is a tad bit stronger and can rev higher for vtec, while the LS bottom end can not.</TD></TR></TABLE>
That's not true.
You can safely rev a stock LS bottom end up to 8200 rpm's as long as you replace your stock rod bolts with some ARP's and you won't have anything to worry about. The only thing weak about the LS bottom end is the rod bolts. Some people even take theirs up to 8500 rpm's with only ARP rod bolts done to the bottom. Search for LS/Vtec builds and it's a common fact.
But on the other hand, to make the best of your LS/Vtec set up you should definitely bump up the compression. Like B16 pistons for example, they will drop right in.
Goodluck
Old Jul 15, 2008 | 01:24 AM
J. Funk's Avatar
Read It https://honda-tech.com/zerothread/1676914
Old Jul 15, 2008 | 02:11 AM
lsvtek's Avatar
Default Re: ls/vtec (J. Funk)
Just built mine in December for my Senior project, A few tips I can give you is, DONT GO CHEAP, but respectable branded items, DO NOT FORGET TO GET ARP ROD BOLTS (this is a must in a reliable ls/vtec), Read the guide J.Funk has told you, and also take your time, double check each bolt, and do not rush this. Good Luck
Old Jul 15, 2008 | 09:44 AM
96lsvtec-t's Avatar
i just finished my lsvtec-t boosting 18psi. i know how some people can be on here so... just hit me up if you have any specific questions or encounter any probs.
Modified by 96lsvtec-t at 10:41 PM 7/15/2008
Old Jul 15, 2008 | 10:04 AM
DraginTeg93's Avatar
Heres a tip dont **** in the wind
Old Jul 15, 2008 | 03:13 PM
VTECth1s's Avatar
The worst way to start your first post!
Bro, go to the Search Field in the upper right corner. Type in LS/VTEC you'll find hundreds of threads on builds, dyno's, setups, etc. There's even a few DIY's on how to build a reliable LS/VTEC or a monster LS/VTEC.
The way I see it, if you have to even ask. Don't even bother going with the setup. Stick with the typical b-series vtec motor swap, or single cam vtec if you plan to stay with d-series.
Old Jul 15, 2008 | 03:53 PM
Pat_S's Avatar
Default Re: ls/vtec (VTECth1s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECth1s &raquo;</TD></TR><TR><TD CLASS="quote">The worst way to start your first post!</TD></TR></TABLE>
I don't quite understand what he's asking us. Tips? Tips to what?
Old Jul 15, 2008 | 04:12 PM
steveo135's Avatar
Default Re: ls/vtec (DraginTeg93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DraginTeg93 &raquo;</TD></TR><TR><TD CLASS="quote">Heres a tip dont **** in the wind </TD></TR></TABLE>
LOL
don't eat cheese before noon
Live every day like it is your last.Crawl into a corner and cry..
Don't put all your eggs in one basket, put all of then in the fridge they will last longer..
Old Jul 16, 2008 | 07:42 AM
DC_Legacy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DuStIn[T.s. &raquo;</TD></TR><TR><TD CLASS="quote">]tips?</TD></TR></TABLE>
Try a search, keyword/HT member <U>BAMBAM</U> for starters.....
Modified by DC_Legacy at 1:49 PM 7/16/2008
Old Jul 16, 2008 | 08:14 AM
Rickdrizzle's Avatar
Jesus Frickin' Christ.
https://honda-tech.com/zerothread?id=1676914
pimpdd101
Mar 8, 2008 12:25 PM
WhoneedsVtec7g'sISplenty
Mar 14, 2006 10:07 AM
xgenn786
Sep 25, 2005 10:28 PM
sshaikh01
Jan 11, 2005 04:53 PM
Doeboy
May 20, 2003 02:45 PM
