ls/vtec
Old Aug 19, 2007 | 12:13 PM
be8teensee1's Avatar
Default ls/vtec
well fixed the codes i was throwing (vtec selonoid . oil pressure) im throwing no codes no but i still have a high idle around 1500. if i plug the hole inside the throttle body it drops to about 1000,1100 and suggestions ? .. its a 2000 ls block with a 94 gsr head . stock intake manifold , holley 68mm tb , aem fuel rail , aem fpr , ect
Old Aug 19, 2007 | 04:31 PM
Rikter's Avatar
readup on how to adjust/set your idle and that will help you.
-Rik
Old Aug 19, 2007 | 04:33 PM
crispy93's Avatar
^ pretty much covers it. its not hard at all
Old Aug 19, 2007 | 04:38 PM
GO-FIGHT-KILL's Avatar
Pretty much.
You should be able to adjust that idle down below 1,000RPM, via the idle adjustment screw.
Old Aug 19, 2007 | 08:03 PM
Default Re: (GO-FIGHT-KILL)
so you guys are saying that even if i plug the hole in the tb (iacv) and that slows the idle speed but its not the problem?
Old Aug 19, 2007 | 08:06 PM
Try adjusting the idle screw, and report back.
Old Aug 19, 2007 | 08:15 PM
hey i was just outside about to set the idle screw , i noticed that the top dizzy bolt is no longer there i wonder if this is a timing issue . the dizzy looks like its pushed as far back as it can towards the firewall .
Old Aug 19, 2007 | 08:16 PM
That's not good.
Old Aug 19, 2007 | 08:40 PM
the bolt is not broken off or anything , its just not in there .
Old Aug 19, 2007 | 08:41 PM
Have access to another B-Series throttle body?
Old Aug 19, 2007 | 08:48 PM
yeah i got the stock one, but the holley thats on there is brand new
Old Aug 19, 2007 | 08:52 PM
Ewww...
Call the manufacturer and ask if it's supposed to be like that.
Old Aug 19, 2007 | 08:55 PM
i was gonna set the dizzy position back towards the middle and see if that helps, then tmrw i can get a timing gun and get it timed
Old Aug 19, 2007 | 08:56 PM
^ Give it a shot.
Old Aug 19, 2007 | 08:57 PM
thanks for the help.
turbohatch96y7
Engine Management and Tuning
Jun 10, 2013 07:42 AM
B18_badboy
May 1, 2011 04:43 PM
james007
Apr 30, 2010 04:26 PM
celticthor
Dec 12, 2008 11:18 AM
BseriesEG
Sep 6, 2008 10:07 AM
