LS Intake Size?
Old Mar 4, 2002 | 07:26 PM
Weslay's Avatar
Default LS Intake Size?
What is the difference in size of an LS and GSR intake pipe? or will a LS intake tube fit up on a GSR?
thanks
Old Mar 4, 2002 | 07:58 PM
Weslay's Avatar
Default Re: LS Intake Size? (Weslay)
Old Mar 4, 2002 | 08:08 PM
ILOVEGIRLS's Avatar
nope. the gsr t/b is in a lower position than the ls so the answer is no.
Old Mar 5, 2002 | 05:33 AM
Weslay's Avatar
Default Re: LS Intake Size? (ILOVEGIRLS)
neone?
Old Mar 5, 2002 | 05:39 AM
LS_racer's Avatar
You wouldn't be able to use an LS intake on a GSR engine nor vice versa as the position of the throttle body is different between the two. If you tried to use for example some cold air intake with an aluminum pipe, it wouldn't fit, unless you bent it, but then you'd compromise that intake both in efficiency and probably in reliability. Besides that, I'm fairly sure the GSR throttle body is slightly larger so you might need different tubing to connect the intake to the throttle body. hope that helps.
integraty95
Jan 12, 2009 02:02 PM
DrewQ1
Jan 31, 2005 07:31 PM
mkiv98
Jan 12, 2005 11:55 PM
PearlWhiteAccord
Dec 17, 2004 02:54 PM
NYCz DA9
Jan 18, 2003 11:46 PM
