ls headers same as gsr headers
Old Apr 7, 2004 | 07:25 PM
ubreak_ubuy's Avatar
Default ls headers same as gsr headers
hi,
doing a gsr swap in my ls teg. apparently the gsr motor didnt come with the exhaust manifold. is my ls one the same? i would assume the gsr one would have a large diameter. thanks everyone
Old Apr 7, 2004 | 07:26 PM
1998_4dr_gsr's Avatar
Default Re: ls headers same as gsr headers (raceinspired)
your correct, it wont fit without modification.
Old Apr 7, 2004 | 07:37 PM
Kendall's Avatar
Default Re: ls headers same as gsr headers (1998_4dr_gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1998_4dr_gsr &raquo;</TD></TR><TR><TD CLASS="quote">your correct, it wont fit without modification.</TD></TR></TABLE>
Incorrect. It will fit fine, and assuming you have the cat and exhaust from your LS setup, it will all bolt up perfectly. I'm not sure of any flow differences between the stock exhaust manifolds, but an upgrade should be planned for the near future anyways. Get a header for an ITR, it will line up with the LS exhaust and cat.
Old Apr 7, 2004 | 08:10 PM
Lord Helmet's Avatar
Default Re: ls headers same as gsr headers (Kendall)
well the ls & gsr exhaust manifold UPPER section is the same. now the lower portion is different. on the ls the o2 senor is mount near the end of the piping of the flange where on the gsr it is mounted on behind the front flange of the cat.
Old Apr 7, 2004 | 10:58 PM
xplanetearth420x's Avatar
Default Re: ls headers same as gsr headers (sleeperciv)
plus ls header has a o2 senser on the header the gsr's dont
Old Apr 10, 2004 | 11:48 PM
ITls1995's Avatar
Default Re: ls headers same as gsr headers (xplanetearth420x)
so an ls stock or aftermarcket header wont fit?
Old Apr 11, 2004 | 12:28 AM
xteg95's Avatar
Default Re: ls headers same as gsr headers (ITls1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITls1995 &raquo;</TD></TR><TR><TD CLASS="quote">so an ls stock or aftermarcket header wont fit?</TD></TR></TABLE>
it will bolt up but its (the LS) is longer.
Old Apr 11, 2004 | 04:39 AM
TurboTony's Avatar
Yes, it will fit with now modifications.
Old Apr 11, 2004 | 05:39 AM
Rory Breaker's Avatar
If you are swapping a 94-99 GSR motor in, the header will bolt up to the head, but will NOT fit the cat. Different flange and length. Same diameter though.
If you are swapping in an 00-01 GSR motor, your LS header should bolt on.
MopdiT
Oct 22, 2007 06:11 PM
mrdeadman
Jul 20, 2005 02:05 PM
StolenTeg
Jun 28, 2004 07:43 PM
vtecdc2
Sep 2, 2002 07:43 PM
MrSmith
Oct 15, 2001 12:30 PM
