Low Compression issue..Help Please!
Old Jul 21, 2008 | 12:31 AM
Dave_Dc2's Avatar
Default Low Compression issue..Help Please!
I compression tested my gsr.. 180,125,125,180..is this making my car lose power and if so how much power is it losing
Old Jul 21, 2008 | 04:29 AM
na+b18c_hatch's Avatar
Default Re: Low Compression issue..Help Please! (Dave_Dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_Dc2 &raquo;</TD></TR><TR><TD CLASS="quote">I compression tested my gsr.. 180,125,125,180..is this making my car lose power and if so how much power is it losing</TD></TR></TABLE>
yes, low compression will cause a loss of power. and if i were you, i wouldn't be worried how much power i was losing.. i'd be more concerned about what i could do to fix the low compression. chances are you have some bad piston rings or valve seals. does your car ever blow blueish/white smoke through the exhaust??
Old Jul 21, 2008 | 10:06 AM
lilvietboy's Avatar
what na, said catch that out.
new pistons will give you a higher compression ratio
Old Jul 21, 2008 | 10:11 AM
ruffrhyder's Avatar
Usually when the two cylinders next to one another are both low, that's a size of a blown HG. Go to autozone or Kragen and get a block tester to see if you got a blown HG.
Old Jul 22, 2008 | 11:18 AM
Dave_Dc2's Avatar
Default Re: (lilvietboy)
well most ppl have been telling me its bent valves bc its not smoking..and if it is its bc i have no cat.
hmtcrxsir
Jul 21, 2009 09:09 PM
Turbofrancis619
Sep 4, 2008 06:18 AM
pipe718
Jun 13, 2008 09:54 AM
b18c5turbo
Jul 15, 2005 02:51 PM
Soon_2b_evil
Nov 16, 2003 07:41 PM
