low beam problem: driver side
Old Mar 25, 2008 | 10:47 AM
dippah's Avatar
Default low beam problem: driver side
searched a bit didnt find anything clear.
i have a 97 Integra and the low beam flickered on and off the other day then ultimately failed. i checked the fuse, its fine, i replaced the bulb and still nothing. how can i get my lights working again? im super poor right now and cant afford a padiddle ticket
Old Mar 25, 2008 | 01:57 PM
dippah's Avatar
Default Re: low beam problem: driver side (dippah)
bump
Old Mar 25, 2008 | 02:04 PM
turboteg90's Avatar
pm for noodz
borrow another bulb from somebody and see if it works,if not check your wires
Old Mar 25, 2008 | 04:17 PM
Blahblah718293's Avatar
Default Re: low beam problem: driver side (turboteg90)
start chasing wires... to begin, (i hope you have a mutli-meter or test light) check for power and ground at the plug, if no, recheck and recheck again the fuses (just cause they look good doesnt mean they are)
if youve got power and ground at the plug, and the fuses are good, then check the relay, its either somthing along those lines or its the wires themselves.
Sgalena
Honda CR-V & Element
Apr 8, 2018 01:50 AM
TheMightySi
10
May 8, 2011 08:13 AM
Edul59
Sep 10, 2010 03:33 PM
ajason24
36
Jun 4, 2009 05:14 PM
kefka
May 22, 2003 11:23 AM
