loose strut.
ive got a 92 gsr, and my left front tokico white is kind of loose. the "threaded piece", for lack of a better term, that comes up in the center of the shock tower with the nut on it turns when i try to tighten down the nut, does this mean the whole strut will need to be replaced?
I forget on those ones, but most struts have a way to hold the shaft while you tighten the nut. Usually with an allen wrench in the top, or a flat spot for a crescent wrench or whatever. Unless it's rusty/corroded, you can usually just zap it tight with an impact gun.
Yes, definitely be careful. For struts, I like to use my 3/8" gun and use short quick trigger pulls. The starting/stopping helps the nut turn instead of just spinning the shaft, and it keeps you from over tightening.
rollinhonda3
Sep 11, 2010 11:36 AM
komat
15
Dec 20, 2004 05:18 PM
nc-rsx-s
Aug 17, 2002 03:51 PM
