Looking at a 2000 integra gs-r with some work done to it, but motor problems
I have been eyeballing this car for a few weeks and I want to get it. The owner says he believes the valves got bent. I have no experience with dohc engines, but I am willing to learn. For 2000 usd, should I get it and repair it, or should I pass on it?
Re: Looking at a 2000 integra gs-r with some work done to it, but motor problems
Originally Posted by Zacht0423
(Post 51931912)
You could always sell the damaged engine and buy a used low mile JDM engine of your choice and swap it in and call it a day, the only issue is since its a 2000 model which is OBD2B you need to find a 2000 and up model engine for everything to plug in easy, there's ways around it but if you had a 1999 model any engine from 96 and up to 99 will directly swap in with ease as far as the wiring harness goes.. But generally if you keep the main parts from the original engine ( engine harness, distributor, alternator and starter you can usually swap it over to the new used USDM or JDM engine and it should work just fine. But I would recommend keeping the original engine and have it rebuilt. |
I found this rebuild kit (https://www.ebay.com/i/320619481833?chn=ps). Is this a trust-able kit? Also, in the event that it isn't, could you point me to one that is please? Thanks.
unless you enjoy long and expensive build projects I'd stay away from it. Chances are it had a broke timing belt or It was over-revved on a downshift. Who knows what other internals are damaged - pistons, scored cylinders, etc.
I don't mind having to spend up to $1000 on fixing the motor. I want to either get the owner to inspect the head and pistons, or get 600 off the price. However, I would like to know some good engine swaps for the car in the event that the engine is completely trashed, preferably one with a timing chain, or one that has a timing chain kit available.
If you're looking to swap in an engine with a timing chain (aka k-series) that's a 4-5 thousand project at the very least assuming you're doing everything yourself. If you know how to work on engines then do the rebuild yourself with the engine that's in there.
Im gonna get a bore scope camera and check the valves and pistons. I've worked on small engines for lawn mowers before, no I'm not completely engine illiterate, but never have I worked on a ohc engine. I have family that have though, and this forum is a wealth of knowledge. Ill post pictures of the insides once I check out the car in person. Thanks for all the help ,too. I really appreciate it.
(Post 51931912)
Do not get that cheap ass ebay rebuild kit. Waste of time, money and effort. Last time I got my B18C1 engine rebuilt by a competent shop, it was $2500 with forged internals and upgraded valves/springs. If you're dead set on getting this chassis, you have a few options: 1. Swap the engine with another working B18C1. An engine swap is much easier than an engine rebuild. 2. Rebuild the engine with stock components. Depending on the damage, this could be 2 or 3x as expensive as a used engine. 3. Rebuild with performance parts. This could be any where from $2500, up to $$$$$$. Depends on your budget. 4. K20Z1 / K20Z3 / K20A2 / K24 swap. Base K20 series are not going to be up to par with the B18C1. More torque, more HP. Likely to cost $5K or more. |
https://www.hmotorsonline.com/b-series/
https://www.ebay.com/itm/OEM-Honda-T...ty!92078!US!-1 https://www.ebay.com/itm/94-01-ACURA...AAAOSwstxVUhhR https://www.ebay.com/itm/OEM-Replace...ox!92078!US!-1 Best deals are here, https://www.icbmotorsport.com/intyrpikitb1.html https://www.icbmotorsport.com/indc2db8tyr.html |
