location and testing of coolant temp sensor and MAP sensor on 90 Teg?
Old Mar 5, 2006 | 04:22 PM
Mrs . M i c h a e l's Avatar
Default location and testing of coolant temp sensor and MAP sensor on 90 Teg?
car is getting bad gas mileage and I was told to check these two sensors. I dont know where they are, nor do I know how to test them.
Old Mar 5, 2006 | 08:16 PM
blkb18's Avatar
Default Re: location and testing of coolant temp sensor and MAP sensor on 90 Teg? (Stacked)
search, search and then search, nothins free.
Old Mar 5, 2006 | 08:33 PM
dotmichael to you
Default Re: location and testing of coolant temp sensor and MAP sensor on 90 Teg? (blkb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkb18 &raquo;</TD></TR><TR><TD CLASS="quote">search, search and then search, nothins free.</TD></TR></TABLE>
...alright sweetheart. go type coolant temperature sensor into archive and tell me where it shows how to test for it and where to find it on a DA integra?
Old Mar 5, 2006 | 08:41 PM
blkb18's Avatar
Default Re: location and testing of coolant temp sensor and MAP sensor on 90 Teg? (. M i c h a e l)
pick up a manual, it will give you the location as well as the graph that will help you convert your ohm reading to a temp reading.
Old Mar 12, 2006 | 05:50 PM
help me out guys
Old Mar 12, 2006 | 07:18 PM
mattcivic's Avatar
blkb18 just did
Old Mar 12, 2006 | 09:50 PM
ugh..
here is what my horrible chilton book says:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chilton &raquo;</TD></TR><TR><TD CLASS="quote">MAP Sensor Removal & Installation
The MAP sensor is located within the emission control box on the firewall. The sensor is located on the firewall next to 2 solenoid valves.
If necessary, remove the control box from its mounts and open the box. Disconnect the wire harness connector to the sensor, then disconnect the vacuum hose(s). Remove the sensor from its mount.
When reassembling, handle the unit carefully. Install it securely in the mounting and attach the vacuum line(s) and wiring connector. Reassemble and install the emissions box.</TD></TR></TABLE>
no pics. nothing on how to test it.
also shows NOTHING about the coolant temperature sensor.
so like i said..help me out.
Old Mar 18, 2006 | 11:10 AM
mr.beeks's Avatar
next to two black cylinders w/hose sticking out to intake
and the sensor you are looking for is black box w/hose sticking from underneath.
coolant sensor the one to the gage goes right underneath the distributor
single plug
for the ecu is in the black of the block near the oil filter
the one w/two plugs is the fan switch another is the oil pressure switch..
ps all those that told him to search
might as well not be here cause you took the time to respond just to reply search...
and yes and something else is free for you and will give it to you anytime..
rdssk8rcs1
Mar 10, 2008 07:52 PM
slowB20ej8
35
Jan 3, 2008 03:10 PM
cigrafix
Sep 19, 2006 04:26 PM
redintegra1998
May 12, 2005 09:29 AM
b16 matt
Jun 27, 2003 01:18 PM
