limited-slip
You will need the F.D ring from an ITR, as well as the matching countershaft. If US spec, then they will be 4.40. IF JDM spec, then 4.785.
Also, try searching, both recent and archives. If you don't, you will get schooled. I found both pieces needed to do this swap by typing
"ITR LSD". Then, in the results, look in the titles for "LS".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwolsten »</TD></TR><TR><TD CLASS="quote">Why wouldn't you be able to put the LS FD gear on the ITR differential? Would it not bolt up?
The inner diameter of the LS ring gear is too small to fit over the ITR LSD. So you will need either an ITR or a GSR ring gear.
spoon23_JDizM AkA SpOoN20
Dec 7, 2003 09:57 AM
