Light harness
Old Oct 10, 2009 | 11:18 AM
im_inn0c3nt's Avatar
Default Light harness
I have a 1998 acura integra and the front end had a wreck and is wanting to put turn signals and stuff back in because previous owner got rid of it and jus snipped the wires and needing both all the way from driver side turn signal harness all the way in back of the fuse box and was wandering if a 1994-97 would work
Old Oct 10, 2009 | 06:31 PM
Default Re: Light harness
help me please
Old Oct 10, 2009 | 07:59 PM
robcivic559's Avatar
Icon6 Re: Light harness
i ran into this too the trun signal and the pigtail and wires the pigtail have two pices a housing for the bulb and pig tail connection to the bulb housing i got the pig tail of the junkyard from a eg civic some parts from the eg you can use on your car i'd find out if the harness is the same i use the pigtail from the eg and it work its just three wire from the pigtail a red ,black, and green if you still have some wires just match the colors you can do this but the side maker you have to find out i didn't have to change hope this helps
Old Oct 10, 2009 | 10:46 PM
well thats actually wat i have done to it now but id rather have the whole harness not uncut u know have it all in one i mean sum of my stuff is rigged on the car and i dont like it id rather have it as a whole and because i want to tuck my wires and if i buy a harness than i could jus rip the one i have out and jus start new ya kno cuz the harness i have now is jus cut at many places and its pretty much jus a big mess
Old Oct 11, 2009 | 02:21 AM
bump could sumbody please help
Old Oct 11, 2009 | 05:26 PM
anyone know this
Old Oct 11, 2009 | 05:32 PM
follie gatts's Avatar
i have no idea if the light harnesses are the same.
that said, there's nothing wrong with wire splices if you solder the joints and wrap them securely after they cool. soldering is easy to learn, and won't rattle loose over time if done properly.
Old Oct 11, 2009 | 10:33 PM
yea true jus really want another due to the fact that previous owner for sum odd reason started cutting and soldering which i would rather have one sold harness u kno its weird jus bein really picky ya kno
Old Oct 13, 2009 | 10:34 AM
ttt
zemerin
May 12, 2014 04:05 PM
jdm_h22
Feb 8, 2008 08:20 PM
g0tVTEC
Feb 14, 2006 06:08 AM
soberstan
Oct 1, 2005 10:05 PM
turbotime
Nov 12, 2004 10:15 PM
