leaky hatch
Old Sep 10, 2006 | 07:06 AM
gsr1289's Avatar
Default leaky hatch
sooo my hatch is leaking and i cant really figuer out where its coming from i know most ppl will say just get in there and have some one dump water on there and see where its coming from but i still cant tell. so my question is has any one else had a leaky trunk and couldnt find where the leak was coming from? also i have a rear wiper delete kit and the lil cap thing doesnt sit very well so it could be leaking from there but ive taken that lil trip panel off the hatch and there was no water so ne suggestions would be appricated.
thanks in advacned
Old Sep 10, 2006 | 10:12 AM
BLKGSR24's Avatar
Default Re: leaky hatch (gsr1289)
Do you have a sunroof? If you do, then I bet the drain tube for it came loose and is leaking into your hatch.
Check out this link for more info http://www.team-integra.net/se...D=546
Old Sep 10, 2006 | 06:06 PM
gsr1289's Avatar
Default Re: leaky hatch (BLKGSR24)
sweet thanks alot i will try and check this out in my shop class tmrw or at my house after school
thanks
Old Sep 10, 2006 | 06:13 PM
CubanLynx84's Avatar
First off check your tailight gaskets. 98% of the time it's the talilights leaking. Pull them off and see what condition they are in. if it's not that then it could be the drain tubes as previously mentioned, if you have a sunroof, or it could be the rear nozzle on the roof or the hatch seal. But check the lights first.
Old Sep 10, 2006 | 08:22 PM
gsr1289's Avatar
Default Re: leaky hatch (CubanLynx84)
yeah ive checked the lights the gaskets seem to be fine but the light is cracked so it lets water into the light casing but the water isnt seeking into the hatch from there. im pretty sure that it is the drain tube cause i think at one time i saw water coming from those side trim pannels but ill deff give it another good hard look over.
thanks guys for the help
chase7687
10
Jun 13, 2011 12:46 PM
head458
Oct 20, 2009 05:38 PM
lscrx8.5
Feb 5, 2006 07:04 PM
tommyboy
Sep 19, 2004 11:45 AM
sxecustoms
May 31, 2003 02:30 PM
