Leaking Oil
I'm pretty new to cars and I just bought an Integra, 205000 miles and its leaking oil. The only thing that I know has been done to the motor is the valve cover gasket has been changed and I was wondering where I should go from here. Thanks! :D
Valve cover and spark plug tube gaskets
Distributor o-ring
Exhaust camshaft end plug
VTEC solenoid gaskets if it's a GS-R/ITR
Camshaft oil seals (both, behind cam gears)
Oil pan gasket
Front main crankshaft oil seal
Rear main crankshaft oil seal (behind flywheel/driveplate)
Oil cooler o-ring (94-95 GS-R and possibly ITR) or oil filter itself
Oil dipstick tube
That's about all I can think of that can leak oil. Check 'em all.
Distributor o-ring
Oil pan gasket
Oil dipstick tube
Thanks everyone for the replies, it looks like its leaking from the Cam Seal. Ordered a new one but do I have to use Hondabond? I read that a lot of people use Permatex Ultra Gray, opinions?
Ultra Grey = Hondabond. I've been using the Permatex stuff for the past decade with no issues whatsoever. Yes I would put it on the cam plug. Did you get the revised plastic plug that comes with o-rings on it? That's what I'm using and it's never leaked. The old original rubber plug design was notorious for leaking.
95halx
Sep 5, 2012 12:35 PM
keilux
53
Aug 17, 2009 05:43 PM
