Leak in trunk
Subscribe
Mar 19, 2006 | 06:12 PM
Anyone have a problem with a leak in the trunk? when it rains, my trunk gets wet. i changed the gasket around the rear tail lights, but that didn't help. any one else run into this problem? how did you fix it?
Reply 0
Mar 19, 2006 | 06:15 PM
Re: Leak in trunk (intgraCA)
My accord used to leak. I have to put new weatherstripping around the trunk....You can also buy a foam that you spray in gaps that seals them so that the trunk will not leak.
Reply 0
Mar 19, 2006 | 06:37 PM
yeah my trunk leaks. i learned to live with it, i have no idea where it comes from. i have redone all the seals. so i try to keep in indoors when it rains or atleast covered
Reply 0
Mar 19, 2006 | 06:49 PM
Re: (vincepru)
put baby powder around suspected areas...close the trunk...run hose water over the trunk..let it sit for a few minutes..open your trunk..and look for the stream where the baby powder is
Reply 0
Mar 19, 2006 | 07:06 PM
had the same problem w 95 ls replaced the hatch weather strip seal with new one from the dealer dry ever since
Reply 0
Mar 19, 2006 | 07:20 PM
Re: (b20integrapower)
THANK YOU B20INTEGRAPOWER!!!!!! My trunk has been leaking for two weeks. Driving me up the freakin wall. I just went out there to do the Baby powder test And it is one of my tail lights. I could easily see the "Trail from the water. THX alot.
Reply 0
Mar 19, 2006 | 10:02 PM
Re: (fliptout2)
no problem bro
Reply 0
Subscribe
