koni yellow users
I've never adjusted the perch via the c-clip...I imagine if you've got gumby arms you could perform the operation with the shock still installed and springs unloaded.
I heard some guy managed to get a spring compressor on the spring
while it was still mounted to the car, and then lowered the circlip.
I would just take them off.
But if your asking because your thinking of buying them, I think the
general procedure would be to remove them first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu »</TD></TR><TR><TD CLASS="quote">I do it all the time, up and down and round and round. No need to remove the assembly
Schu</TD></TR></TABLE>
You must have springs that lower the car so much that they aren't compressed at all when the car is raised up off the ground.
It would be different w/ the sp3's the rod is shorter and the
spring (depending on what ones you have) is not decompressed.
I can see how that would be easy with the OTS yellows.
mikzsan
Suspension & Brakes
15
May 8, 2012 02:44 PM
