Key failure
Old Apr 3, 2005 | 07:34 PM
ferio 95's Avatar
Default Key failure
Ok ive been having the weirdest **** going on with my key. i put the key in and turn it to the on position. nothing happens. the dash lights are supposed to come on but never do. i have to wiggle the key abck and forward to get it to a specific point then the lights come on then i can start it. now if the key gets moved a hair buy bumping it or hitting a pothole the car shuts off. also when i try to start the car by turning the key it wont start so i had to wire a push button for it. any idea on why this is happening?
Old Apr 3, 2005 | 07:36 PM
Kendall's Avatar
Either wear on the key, or wear in the keyhole.
Old Apr 3, 2005 | 08:41 PM
95lstegman's Avatar
Default Re: (Kendall)
usually wear on the key. try to find the valet key, and have a regular master key made from that. the only difference is the thickness of the key, so it shouldn't be a problem.
Old Apr 3, 2005 | 09:04 PM
ferio 95's Avatar
Default Re: (95lstegman)
i highly doubt it has anything to do wit the key itself but at the same time i havent tested the theory and cant since i lost the master key and just have two spares one of which ive tested
Old Apr 4, 2005 | 03:46 AM
95lstegman's Avatar
Default Re: (ferio 95)
well, i've owned 3 hondas, and all have shown key wear on the master key, which was used regularly. so, i switched to using the valet with the first car, and that key was just like new, no wear at all. never had a problem with it, and it works every time, unlike the original.
as for copies, take your VIN to honda and they should be able to make you a new master key, perfect for your car. it will cost like $40, but you'll never have this **** again unless you own the car for like 150k more miles
Old Apr 4, 2005 | 05:37 AM
ferio 95's Avatar
that sounds promising and now that i think about i didnt start having key failure till i switched over to a set of copies i had made. but it didnt happen right away. it first started out by not wanting to start like there was a short in the starter signal. i really cant remember. so there is no way any of this can be electrical?
Old Apr 4, 2005 | 01:15 PM
f2rider's Avatar
Default Re: Key failure (ferio 95)
I had a similar problem and I just took my VIN # to Acura and had a key made from it and haven't had a problem since.
Old Apr 4, 2005 | 01:23 PM
95lstegman's Avatar
Default Re: Key failure (f2rider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio 95 &raquo;</TD></TR><TR><TD CLASS="quote">so there is no way any of this can be electrical?</TD></TR></TABLE>
no.
Old Apr 4, 2005 | 01:24 PM
SoEvoL's Avatar
Default Re: Key failure (95lstegman)
make sure ur key isnt bent, sometimes if it has a slight bend it can cause it not to line up or turn
Old Apr 4, 2005 | 02:34 PM
ferio 95's Avatar
Default Re: Key failure (JDMCrx89)
ok so i gather that if i replace 24, 4, or my key by way of the dealership everything should be A ok?
Old Apr 4, 2005 | 03:04 PM
95lstegman's Avatar
why would you replace 24 or 4? just get a new key and make a couple copies of it
Old Apr 4, 2005 | 03:06 PM
RHDintegXsi's Avatar
ignition switch
Old Apr 4, 2005 | 03:25 PM
ferio 95's Avatar
Default Re: Key failure (SINFULintegXsi)
well i said 4 refering to the whole column thing and 24 because i thought it may be an electrical issue. everyone seems to agree its the key so ill take my chances and get a key made at acura first thing
Old Apr 4, 2005 | 08:56 PM
if your not having a problem physically turning the key..its not they key or the key cylinder..from experience i can almost bet its the ignition switch..ive seen the points get worn down and had problems such as the yours
Old Apr 4, 2005 | 09:10 PM
Kendall's Avatar
Being logical, since we can't directly identify whether it's the key or the switch, it makes sense to replace the cheaper item first.
Old Apr 4, 2005 | 11:44 PM
ferio 95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SINFULintegXsi &raquo;</TD></TR><TR><TD CLASS="quote">if your not having a problem physically turning the key..its not they key or the key cylinder..from experience i can almost bet its the ignition switch..ive seen the points get worn down and had problems such as the yours</TD></TR></TABLE>this sounds more like what im dealing with. it seems like what ever contacts are supposed to be touching at what ever key position arnt touching good. i have no problem at all turning the key or removing it.
Old Apr 5, 2005 | 05:03 AM
97tegGS's Avatar
Might as well be the actual ignition switch. Parts like that get worn out all the time.
Old Apr 5, 2005 | 06:12 AM
95lstegman's Avatar
Default Re: (97tegGS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97tegGS &raquo;</TD></TR><TR><TD CLASS="quote">Might as well be the actual ignition switch. Parts like that get worn out all the time.</TD></TR></TABLE>
i've had 3 hondas, one with 220k miles, one with 95k, and another with 176k. and i deal with hondas every day. never seen an ignition switch go bad in a honda. now, take a chrysler or ford or something, then yes, i've seen those go bad just from people having heavy keychains on their car key, but never a honda.
Old Apr 5, 2005 | 09:23 AM
ferio 95's Avatar
well ive seen some **** happen on my own car that ive never seen hondas do before and i like to consider my self well versed in whats common and uncommon for a honda but this just kinda throws me for a loop. so im just going to replace both since the harness is only 25 bux and the key isnt that much either
Old Apr 5, 2005 | 09:27 AM
95lstegman's Avatar
why do that when you could replace one, see if that fixes it, then the other. i'd try the key first, but it's your car. oh, and i don't think the harness is to blame. it's the switch.
Old Apr 5, 2005 | 08:59 PM
ferio 95's Avatar
ok on my way to work the car just took a **** so i had to figure it out and get to work on time. i manage to get it to work by holding the key in the start up position and driving with one hand (starter is wired threw horn which is the only reason this workd) anyways, i dismantled the white cap on the column and found that the contacts on the inside had infact been glazed over and where not making good connections so i took a knife and filled them down and everything works great now so now i no what i need to replace
Old Apr 5, 2005 | 09:07 PM
SYTFU Tommy.'s Avatar
actully a new key from the stealership is $7. jsut bring proof of ownership and ur VIN number
Old Apr 5, 2005 | 11:27 PM
Stripped Honda's Avatar
99-0104
Default Re: (tngay)
change the ignition pigtail #24 that is your problem i see it happen all the time
Old Apr 6, 2005 | 03:41 AM
tegsallgood's Avatar
when does something like this usually start happening?
Old Apr 6, 2005 | 06:31 AM
GrayT's Avatar
Default Re: (tegsallgood)
It would seem obvious to me it depends on how many times you insert the key into the ignition Or of course at approximately 112,763 miles.
