K20 Possibilities?
Old Jul 7, 2007 | 07:21 PM
Devil May Cry's Avatar
Default K20 Possibilities?
is it difficult putting a K20 Into my DA? I was debating on puttin some real power into my DA. Do they even have the mounts for this process? Upgrading from LS/Vtec.
Old Jul 7, 2007 | 07:30 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
anything is possible with time and money
Old Jul 7, 2007 | 07:48 PM
numbnuts22715's Avatar
Default Re: (DOHCgarage919)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCgarage919 &raquo;</TD></TR><TR><TD CLASS="quote">anything is possible with time and money</TD></TR></TABLE>
True, but i'm getting a little tired of this answer, because that doesnt really tell them anything.
Putting a k series engine in an integra can cost in the upwards of 10 grand. Is 201 or so hp at the fly worth it to you?
Old Jul 7, 2007 | 07:50 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (numbnuts22715)
If the OP is indeed in Tokyo, the K20 swap may be cheap.
Old Jul 7, 2007 | 07:57 PM
Default Re: (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">If the OP is indeed in Tokyo, the K20 swap may be cheap.</TD></TR></TABLE>
That's true.. I really didnt even notice that. But from my understanding, it's not only the parts that cause the problem with the expense. What kind of goals do you have for your car? How much experience would you say you have working on cars?
you'll probbaly need to fabricate a few things.
Old Jul 7, 2007 | 08:16 PM
it will not cost 10 grand to put in a k20 my friend bought a wrecked rsx type s for 2,500 swapped motor in of cousre he need to buy a few things here and there like mounts etc but cost him little over 4 grand i think
Old Jul 7, 2007 | 08:18 PM
just a k20 motor cost around 5-6 grand where did you get 10 grand from u must be on crack u might as well build a boosted b-seires with 10 gs
Old Jul 7, 2007 | 08:46 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">
Putting a k series engine in an integra can cost in the upwards of 10 grand. Is 201 or so hp at the fly worth it to you?</TD></TR></TABLE>
10k? maybe if you plate the engine in gold. like someone else said you can get a wrecked rsx for 2-3k. for 10k you can rebuild the motor and get a turbo on there.
Old Jul 7, 2007 | 09:35 PM
MikeSarr_GSR's Avatar
Default Re: (vladd)
unlike b-series you dont see too many budget k-swaps being done in garages. it takes more tools, some fabrication and time from a skilled technician to perform the swap. might not be as expensive as people say, however do not expect it to be turn-key. if a shop promised to sell you a completed swap for $8500 motor, parts and labor included,
that would be about par from what I can tell.
Old Jul 7, 2007 | 09:37 PM
Doostur's Avatar
B Series for life.
Old Jul 7, 2007 | 09:49 PM
vladd's Avatar
Default Re: (MikeSarr_GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeSarr_GSR &raquo;</TD></TR><TR><TD CLASS="quote">unlike b-series you dont see too many budget k-swaps being done in garages. it takes more tools, some fabrication and time from a skilled technician to perform the swap. might not be as expensive as people say, however do not expect it to be turn-key. if a shop promised to sell you a completed swap for $8500 motor, parts and labor included,
that would be about par from what I can tell.</TD></TR></TABLE>
so 5-6k for the extra parts and labor? do people actually pay that much?? it's called a project car for a reason; you do it as a project. saving that much cash alone makes it worth the time to learn how to do it yourself.
Old Jul 10, 2007 | 09:38 AM
jdmjunkie8's Avatar
Default Re: K20 Possibilities? (Devil May Cry)
B series for life, you would be better off with a actual itr swap.
Old Jul 12, 2007 | 01:02 PM
dwolsten's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeSarr_GSR &raquo;</TD></TR><TR><TD CLASS="quote">unlike b-series you dont see too many budget k-swaps being done in garages. it takes more tools, some fabrication and time from a skilled technician to perform the swap. might not be as expensive as people say, however do not expect it to be turn-key.</TD></TR></TABLE>
Huh? Maybe I'm missing something, but from everything I've read, a K-swap doesn't require any special fabrication. There's mount kits available from several different companies, axles as well, wiring harnesses, a shifter kit from Karcepts, and probably a header too. What more do you need for a bolt-in installation?
Modified by dwolsten at 5:34 PM 7/12/2007
Old Jul 12, 2007 | 02:48 PM
InvaderJim's Avatar
http://www.g2ic.com/forums/showthread.php?t=164905
Old Jul 12, 2007 | 03:24 PM
dohcMONSTER's Avatar
Default Re: (dwolsten)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwolsten &raquo;</TD></TR><TR><TD CLASS="quote">
Huh? Maybe I'm missing something, but from everything I've read, a K-swap doesn't require and special fabrication. There's mount kits available from several different companies, axles as well, wiring harnesses, a shifter kit from Karcepts, and probably a header too. What more do you need for a bolt-in installation?
You have to cut out the shifter area to accomadate the karcepts shifter box, it doesnt just bolt right up you have to cut a good sized piece of your floor out to get it to work correctly.
Old Jul 12, 2007 | 04:34 PM
dwolsten's Avatar
Default Re: (dohcMONSTER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcMONSTER &raquo;</TD></TR><TR><TD CLASS="quote">You have to cut out the shifter area to accomadate the karcepts shifter box, it doesnt just bolt right up you have to cut a good sized piece of your floor out to get it to work correctly.</TD></TR></TABLE>
Ok, but that still doesn't sound like "fabrication" or "time from a skilled technician" to me, just a few minutes with a sawzall. The previous post makes it sound like a K-swap requires welding or some other work requiring special tools and skills which most DIYers don't have, and that just doesn't seem to be the case.
Old Jul 13, 2007 | 08:04 PM
InvaderJim's Avatar
Well when I go to do mine I'll be sure to make a thread so everyone can see. haha
Old Jul 13, 2007 | 08:46 PM
CapnKrunch's Avatar
Default Re: (InvaderJim)
h2b &gt; k20
Old Jul 13, 2007 | 09:41 PM
alexisthemovie's Avatar
https://honda-tech.com/zerothread?id=1720666
hrs-parker
May 17, 2008 01:15 PM
Kentagious
Nov 21, 2007 03:17 PM
mars-EF-LS
22
Oct 9, 2007 08:02 PM
p1ccoloz
Dec 29, 2006 03:09 PM
EngineNoO9
Honda Motorcycles
Nov 14, 2006 02:50 PM
