K&N Drop in filter (almost)?
Old Apr 15, 2004 | 07:31 AM
wreckedmyteg's Avatar
Default K&N Drop in filter (almost)?
A while back I thought I read about a way to make a drop in K&N filter. Something about chopping the end off the stock filter, and using it to adapt the K&N to the filter box.
What's the part number for the K&N filter? I want to try this.
Old Apr 15, 2004 | 10:18 AM
dip-set's Avatar
Default Re: K&N Drop in filter (almost)? (wreckedmyteg)
just buy the drop in...i think its part number e-2427
Old Apr 15, 2004 | 01:30 PM
lsteg99's Avatar
here, http://www.geocities.com/bretq/modifications.html
Old Apr 15, 2004 | 02:42 PM
Default Re: (lsteg99)
Nice site...exactly what I was looking for.
Do you perfer the larger or smaller K&N filter. I saw two pictured.
Old Apr 15, 2004 | 02:51 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (wreckedmyteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wreckedmyteg &raquo;</TD></TR><TR><TD CLASS="quote">Nice site...exactly what I was looking for.
Do you perfer the larger or smaller K&N filter. I saw two pictured.</TD></TR></TABLE>
The RU-2820 is the best choice, when used w/ the stock filter's neck and endcap, the size is pretty much exactly the same as stock.
Old Apr 16, 2004 | 03:27 PM
trutuner's Avatar
Default Re: (PatrickGSR94)
anyone ever do this with a compteech system?....seeing as this is what im trying to do now!
Old Apr 16, 2004 | 03:52 PM
Community Builder
Default Re: (trutuner)
doesn't the Comptech Icebox's tube already bend forward and you just strap the K&N onto the tube? I'm pretty sure that's right, there's no need to use any stock filter parts in that case, only if you want to use a K&N in your stock airbox.
Old Apr 16, 2004 | 03:55 PM
trutuner's Avatar
well that could be true, but i onl have the comptech ice box, no arm!, i was thinking of mating my stock arm + k&n + comptech to make the best cai out there? ...-Roger
Old Apr 16, 2004 | 04:07 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trutuner &raquo;</TD></TR><TR><TD CLASS="quote">well that could be true, but i onl have the comptech ice box, no arm!, i was thinking of mating my stock arm + k&n + comptech to make the best cai out there? ...-Roger</TD></TR></TABLE>
Well part of the gains from the Comptech system come from using the tube which is larger in diamter than stock and also smooth inside. I bet you could use most any short-ram intake arm that is made specifically for a GS-R.
Looks like most other GS-R short-ram intake arms going by this pic:
Old Apr 16, 2004 | 04:27 PM
integranator's Avatar
obviously, that one won't work for gsr's, so it won't be like most.
Old Apr 17, 2004 | 04:28 AM
Community Builder
Default Re: (integranator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integranator &raquo;</TD></TR><TR><TD CLASS="quote">obviously, that one won't work for gsr's, so it won't be like most.</TD></TR></TABLE>
My point was that the tube bends at the end so that it faces forward, unlike most generic intake tubes for Civics that have only the one bend up by the throttle body.
Old Apr 18, 2004 | 06:32 PM
Bombadil's Avatar
Are any additional modifications needed to use the RU-2820? Or is it the same process as shown on the link to the 3130? Break off the white plastic part & mesh and install the 2820 using the original clamp ring.
Looks too easy to be true.
Old Apr 18, 2004 | 06:39 PM
Bombadil's Avatar
Never mind, I did a search and found my answers.
typeR564
Aug 12, 2007 08:13 PM
mrdeadman
May 3, 2006 01:19 PM
