JDM headlight wiring problem
Old Mar 11, 2008 | 10:11 AM
JmurGSR98's Avatar
Default JDM headlight wiring problem
I'm trying to wire my jdm conversion headlights. The passenger side headlights all work but only some of the drivers side lights work. I used the headlight wiring diagram found in the FAQ but when my car was stolen, the corner lights were ripped out. Now when I finished wiring everything, the drivers side headlight is very dim. The high beam doesn't work at all. When I turn the parking lights on, the side marker is on, but when I turn the lights all the way on, the side marker goes out and the turn signal comes on. This is all on the drivers side. The passenger side lights all work fine. All my fuses are good. I switched low beam bulbs and the passenger side worked perfect while the driver side illuminated very dim.
Old Mar 11, 2008 | 05:25 PM
JmurGSR98's Avatar
Default Re: JDM headlight wiring problem (JmurGSR98)
anyone have any ideas? is there a certain voltage between the side markers and turn signals that can help me find out what wires are what since my lights were ripped out?
Old Mar 11, 2008 | 07:42 PM
JDMDC2BOY12's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JmurGSR98 &raquo;</TD></TR><TR><TD CLASS="quote">anyone have any ideas? is there a certain voltage between the side markers and turn signals that can help me find out what wires are what since my lights were ripped out? </TD></TR></TABLE>man nver heard of that problem before.. my suggestion is try to rewire all the wiring again that way u will know what u did wrong...
Old Mar 12, 2008 | 05:56 AM
JmurGSR98's Avatar
Default Re: JDM headlight wiring problem (JDMDC2BOY12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDC2BOY12 &raquo;</TD></TR><TR><TD CLASS="quote">man nver heard of that problem before.. my suggestion is try to rewire all the wiring again that way u will know what u did wrong... </TD></TR></TABLE>
Yeah, i rewired the drivers side and it stayed the same. Yet I wired it exactly the same as the passengers side and that side works perfect.
Also, why would my driver side low beam be so dim if you don't touch that. It just plugs into the housing. Switched bulbs and the bulb worked fine on the passenger side. Does every wire in the engine bay need to be connected, even wires not for the lights? I've got a couple of wires that were ripped out in front of the radiator. They're not connected yet. Could that be a problem? Maybe they need to be grounded?
Old Mar 12, 2008 | 07:59 AM
yes they need to be grounded... that might be it but im not really sure.. soory but im a wire goru..
Old Mar 12, 2008 | 03:08 PM
JmurGSR98's Avatar
thanks. I'll try to find out if that works.
Naudlee
Nov 27, 2008 08:26 AM
jdmcivic1
Apr 23, 2008 08:27 PM
B18 Piston
Apr 17, 2007 11:02 PM
EscaBoi
33
Apr 16, 2007 08:40 PM
