JDM headlight question
Old May 2, 2003 | 01:57 PM
siis2fast's Avatar
Default JDM headlight question
whats the bulb that is used for the fog lights???
a 65watt h3?
Old May 2, 2003 | 04:56 PM
Padawan's Avatar
Darth ModerVader
Default Re: JDM headlight question (siis2fast)
55 watt H3. You really don't want to run higher wattage bulbs in the JDM foglights, because the internal yellow filter has been known to crack because of the increased heat.
Old May 2, 2003 | 05:01 PM
JDC2's Avatar
Default Re: JDM headlight question (Padawan)
i heard somepeople run higher wattage. I still use the 55w just to be on the safe side.
Old May 2, 2003 | 05:32 PM
Padawan's Avatar
Darth ModerVader
Default Re: JDM headlight question (JDC2)
https://honda-tech.com/zerothread?id=485172
https://honda-tech.com/zerothread?id=175891
Old May 2, 2003 | 05:39 PM
Flamenco-T's Avatar
you still will burn and crack the yellow reflector with H3 55W. for soem strange reason, the OEM honda is hte one that never cause it to crack the yellow reflector.
just take the yellow reflector out and run yellow bulbs
stan
Old May 2, 2003 | 10:07 PM
ingrate's Avatar
25 Year Member
Default Re: JDM headlight question (Flamenco-T)
how long have you had the 55w h3's before it cracked the housing? i've had mine for a while now and so far so good
98HypeArrr
Jul 28, 2010 12:48 PM
N4me (06civicsi)
Honda Civic (2006 - 2015)
Dec 20, 2006 08:21 PM
Luminics
162
Mar 18, 2005 08:25 AM
Ibuprofen
Mar 19, 2002 10:10 PM
