JDM header after install question...??????????????
Old Mar 5, 2003 | 12:44 AM
BlkGSR's Avatar
Default JDM header after install question...??????????????
After installing the donut gasket for the 2.5 collector i noticed that the flange on the header does not meet (touch) the cat due to the donut. I have approximate a 1/2" gap. Does everyone else have the same result?
Also, what did everyone use for the support bracket (arm) near the O2 sensor on the ITR header?
[Modified by BlkGSR, 1:50 AM 3/5/2003]
Old Mar 5, 2003 | 02:50 AM
slomob18b's Avatar
Default Re: JDM header after install question...?????????????? (BlkGSR)
i think you need a bigger flange on your cat.
Old Mar 5, 2003 | 11:02 AM
BlkGSR's Avatar
Default Re: JDM header after install question...?????????????? (slomob18b)
its a jdm header and cat??
Old Mar 5, 2003 | 12:46 PM
Aaron M's Avatar
are you using your stock cat?
Old Mar 5, 2003 | 06:00 PM
BlkGSR's Avatar
Default Re: JDM header after install question...?????????????? (SilverB18C1)
sorry.. no. Im using a jdm header and jdm cat.
Old Mar 5, 2003 | 08:25 PM
PoW3l2BaN's Avatar
i think that gap is normal. Its there to compensate for the flex and torque of the engine. Thats why you have those spring bolts holding it in place.
Old Mar 6, 2003 | 05:03 AM
BlkGSR's Avatar
Default Re: JDM header after install question...?????????????? (Jay Hovah)
For the support bracket, there's something you can get at inlinefour.com
check that out
ill do that, thanks.
jeremy_dane
Feb 20, 2009 09:07 AM
98cwitr
Dec 15, 2002 11:34 PM
Wildohiorice
May 1, 2002 08:38 PM
1.8 Hybrid
Apr 29, 2002 11:31 AM
Got-VTEC
Feb 27, 2002 05:51 PM
