Jdm Cluster
I recently bought a JDM cluster and when i installed it,there is one plug left over from the USDM harness.
so my problem is that after i installed it,my fuel doesn't register and my seatbelt light stays on.So i was wondering if someone could help me out with this.Do i have i have to tap the left over wires into one of the other harnesses?.If soo which wires do i have to do this with?.
Well thanks in advance
Justin
Justin
you don't have to do any tapping. All you need is the two blue plugs to be plugged in. Try taking the green film piece off your stock cluster and swapping onto the jdm cluster.
i did mine this way take bothe clsuters and unscrew the 3 bolts behind each of the four pods out and take them out. In other words you will be keeping you original dash cluster but you will swap in the jdm pods (tach, speedo, temp, fuel,) this way you cut nothin and it will work perfect
EGJdmJreams
Nov 12, 2004 06:42 PM
