itr lsd
Old May 20, 2003 | 05:04 PM
TeamSTEALTH GSR's Avatar
Default itr lsd
does the itr lsd tranny use a gear or clutch type lsd?
i have heard that its gears and i also have heard from a reaonable source that "its 100% clutchs"
i know you guys would know the real answer...
gears or clutchs? which one is it?
Old May 20, 2003 | 06:18 PM
Lord Helmet's Avatar
Default Re: itr lsd (TeamSTEALTH GSR)
I'm 100% its gear driven like the quaife lsd is.
Old May 20, 2003 | 06:50 PM
Cone's Avatar
Default Re: itr lsd (sleeperciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">I'm 100% its gear driven like the quaife lsd is.</TD></TR></TABLE>
Old May 20, 2003 | 06:59 PM
NUTWEAVE's Avatar
Default Re: itr lsd (Stealth 95 GS-R)
gear driven.
not that good of a LSD from what i hear. buddy of mine has one in his LS/VTEC hatch, when he is launching, he has to turn the wheels a bit for the LSD to engage. it's not like the Quaife where it's on the whole time.
Old May 20, 2003 | 07:01 PM
NeoGSR's Avatar
Default Re: itr lsd (NUTWEAVE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NUTWEAVE &raquo;</TD></TR><TR><TD CLASS="quote">gear driven.
not that good of a LSD from what i hear. buddy of mine has one in his LS/VTEC hatch, when he is launching, he has to turn the wheels a bit for the LSD to engage. it's not like the Quaife where it's on the whole time.</TD></TR></TABLE>
mine works great....
Old May 20, 2003 | 07:09 PM
Heisdan's Avatar
Which trannys does this come in.. all JDM trannys or .. all JDM integra trannys..
(I need a good site to read about JDM spec cars.. not many out there)
Old May 20, 2003 | 07:26 PM
threatcon13's Avatar
New User
not that good of a LSD from what i hear. buddy of mine has one in his LS/VTEC hatch, when he is launching, he has to turn the wheels a bit for the LSD to engage. it's not like the Quaife where it's on the whole time.</TD></TR></TABLE> thats funny..mine works fine. no lsd is "on" the whole time
Old May 20, 2003 | 07:47 PM
Cone's Avatar
Default Re: itr lsd (Threatcon13)
the Quaife and the ITR LSD are both a helical gear type LSD, basically the same design. It doesn't turn on and off...NUTWEAVE, your friend might be a little off about what he is talking about...the LSD is in all ITR trannies, and was an option on JDM cars (B16 and B18 equipped cars)...HTH...
-Andrew
Modified by Stealth 95 GS-R at 12:02 AM 5/21/2003
Modified by Stealth 95 GS-R at 12:03 AM 5/21/2003
Old May 20, 2003 | 08:58 PM
WiggiE's Avatar
New User
HAHAHA....he magically engages the LSD with a slight turn of the wheel. What does he engage his VTEC with? His brake pedal?
Old May 20, 2003 | 10:08 PM
bhive9024's Avatar
Default Re: itr lsd (WiggiE)
from what I understand the biggest diff. b/t the two is the quaife has more teeth/greater surface area than the ITR.
someone please affirm or correct me
Old May 21, 2003 | 06:07 AM
au-gsr's Avatar
Default Re: itr lsd (bhive9024)
it attaches to the final drive.
hence it is a gear driven lsd
the itr lsd can handle loads of up to 300 pounds of torque
the quaife has a lifetime warranty.
quaife's go for about 900
and itr's can be had for 300-500 on ebay
go here and look
http://acuraautomotiveparts.or...USING
Old May 21, 2003 | 09:17 AM
when people told me that it is clutch type, thats the reason they gave me..... they said the clutchs slip until it warms up and then starts to work.
but looks like u guys know for sure that its with gears.....
thnx
littlerichie34
Feb 27, 2009 01:37 PM
civichbcx
Nov 16, 2005 12:01 PM
mr devious illusions
Mar 16, 2004 11:27 AM
Sliced Beard
Feb 10, 2004 05:27 AM
Sleeper32
Oct 21, 2003 10:53 AM
