itr headers?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pat_S »</TD></TR><TR><TD CLASS="quote">Yes, it will fit. You will need to have a compatable converter and cat-back system.</TD></TR></TABLE>
it will bolt on to your engine.but the down pipe flange will be off.it will bolt on to your intermediate pipe too. u need to have a muffler shop cut/extend and weld for you
i used a dc sports jdm itr header on my 99 obd2 ls. everything bolted up fine . the only modification i did was i had to drill 2 new holes for the cat to collector. now the exhaust ports don't exactly line up perfect, but they do bolt up!
I have the 98 jdm spec headers w/ pwjdm test pipe. I had to get the oem itr collector gasket. I also have a 2 1/2 magnaflow high flow cat w/ blox flange.
The ITR headers can fit any B series. 90-01, vtec/non vtec.
SilverDc2
Oct 23, 2002 03:06 PM
