Issue with running lights...
Old Feb 2, 2012 | 07:31 PM
soledout407's Avatar
Default Issue with running lights...
Hey guys i've recently started having an issue with the running lights and instrument lights in my car. They just have gone out completely, when I use my turn signal or tap my brakes the lights turn on like normal. The instrument lights do not turn on at all as well. This is something that just happened over night. Does any one have any ideas on how i can fix this? Thanks in advance.
Old Feb 2, 2012 | 07:45 PM
Default Re: Issue with running lights...
Just figured I would add its a 2001 4 door integra.
Old Feb 2, 2012 | 08:34 PM
Dannyx321's Avatar
already checked fuses?
Old Feb 2, 2012 | 08:46 PM
I was checking out the fuses but i don't have my fuse cover for underneath the dash so i really don't have an idea as to what fuses are for what.
Old Feb 3, 2012 | 05:30 AM
Dannyx321's Avatar
https://honda-tech.com/forums/acura-integra-6/does-anyone-know-where-find-94-integra-ls-fuse-box-diagram-underdash-1933076/
Old Feb 3, 2012 | 01:46 PM
Ok so i took a look at the fuse diagram for underneath the dash and none of the fuses looked to be blown... Where should I look next? Could there be a bad relay?
Old Feb 3, 2012 | 01:51 PM
dntnedvtec's Avatar
Waiting for FCM.......he is more into the electrical stuff....
Old Feb 3, 2012 | 02:00 PM
TunerN00b's Avatar
You only visually checked the fuses? Stop looking and start actually testing.
Bust out the multimeter and do a continuity test.
Relays can (and in this case, probably should) be tested as well.
Old Feb 3, 2012 | 02:14 PM
Okay i probably should have worded that better, I tested and replaced the fuses for the running lights, running lights relay, license lights and instrument lights but still nothing. Where would the relay for the running lights be located? thanks again for your help guys
Old Feb 3, 2012 | 03:32 PM
Dannyx321's Avatar
you checked the one under the hood too?
Old Feb 3, 2012 | 05:17 PM
No I didn't look under the hood, which fuse would it be under there?
Old Feb 3, 2012 | 06:03 PM
Dannyx321's Avatar
https://honda-tech.com/forums/acura-integra-6/dc-integra-underhood-fuse-box-2343315/
check the interior light
Old Feb 3, 2012 | 06:32 PM
Alright i just checked under the hood and that fuse is good too.
sweatyjack
Sep 11, 2013 06:10 AM
95silverteg
Sep 30, 2008 04:48 AM
JDM H22
Dec 13, 2007 01:59 PM
xxx
Oct 31, 2005 06:57 PM
