integras and wheel rub?
Old Jun 25, 2004 | 10:04 PM
96tegls's Avatar
Default integras and wheel rub?
my integra when it gets low my wheels rub horrible, my old civic never had problems like this. yet i see slamed dc2 tegs all over on H-T so do you guys have the same problems or did you fix them and how? thanks
Old Jun 26, 2004 | 12:50 AM
LowTEC SaiMike's Avatar
Default Re: integras and wheel rub? (96tegls)
are u talking about ur car bottoming out ?
Old Jun 26, 2004 | 08:57 AM
patmcd's Avatar
Default Re: integras and wheel rub? (BomBoi)
what size tires and wheels are you running?
Old Jun 26, 2004 | 10:27 AM
216.226.142.95:27016's Avatar
Default Re: integras and wheel rub? (patmcd)
stock rims or aftermarket? if after market, it must be the offset.
Old Jun 26, 2004 | 11:14 AM
dclsvtec's Avatar
i have this problem.. its cause i have a set of 17s on and it rubs sick the way i solved most of it is i just dont hit bumps to hard or ill just let it happen. another way you can fix this is get a 195 50 15 wheel. the tire wont rub because its smaller than the stock size and it will lower your car even more. after i did that i didnt rub anymore it worked good... no rub and sick dumped
Old Jun 26, 2004 | 01:27 PM
jdm_lover's Avatar
Default Re: integras and wheel rub? (dclsvtec)
Check your alignment...or your toe...because...when your alignment swerves left to right...no matter how low your car is.....it shouldnt rub if you have a good alignment...i had 205/60s on 16s and i adjusted my toe to be streight...and went on with those tires forever! till i hit a nail in the road...:D...so check your toe if your front tires point outwards, cause that might be your problem right there...
Old Jun 26, 2004 | 01:46 PM
G-bonic's Avatar
Hijacked
WUT KINDA RIMS U GOT AND WUT SIZE OF TIRE? AND HOW LOW IS UR CAR ???
Old Jun 26, 2004 | 02:03 PM
GrafxDesignGuy's Avatar
Default Re: integras and wheel rub? (Stock_LS)
Just ghetto rig it and roll your fenders up with a baseball bat... heheh Hey what ever works and its free...
http://www.team-integra.net/se...nders
Old Jun 26, 2004 | 03:47 PM
96tegls's Avatar
ok well i have 17s and a friend put free tires on them hey why not and i find out there 50 series so back rubs alot. but i had 15s on just before and driver strut is kinda weak and i didnt have it to low but when i hit bumps they rubed wheel well in front hard. it grinded thro plastic and hits a metal seam right there. anyone have that problem even passener side is rubbed thro to that?
Old Jun 26, 2004 | 03:49 PM
96tegls's Avatar
also think im sellin 17s soon too. i like the size sometimes but to much hassle
Old Jun 26, 2004 | 03:59 PM
95teggyls's Avatar
just buy new cambers.
Old Jun 26, 2004 | 04:53 PM
corona's Avatar
Default Re: integras and wheel rub? (jdm_lover)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_lover &raquo;</TD></TR><TR><TD CLASS="quote">i had 205/60s on 16s</TD></TR></TABLE>
i'd have to see it to believe it.
that's like running a 20" rim with a 205/35/20 tire
you weren't lowered, i assume?
Old Jun 26, 2004 | 09:12 PM
GS-Rdriven's Avatar
Default Re: integras and wheel rub? (corona)
get a baseball bat and roll ur fenders...if ur signed up with team-integra.net...dey tell u step by step how to do it if u don't know how to ...
Old Jun 26, 2004 | 09:55 PM
96tegls's Avatar
so one hit the metal seam yet i take it that weird and why am i. is this normal?
Old Jun 27, 2004 | 12:07 AM
JFG Kevin's Avatar
Default Re: integras and wheel rub? (GS-Rdriven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GS-Rdriven &raquo;</TD></TR><TR><TD CLASS="quote">get a baseball bat and roll ur fenders...if ur signed up with team-integra.net...dey tell u step by step how to do it if u don't know how to ... </TD></TR></TABLE>
....good idea....go me...i have a rubbing problem because my springs are too soft and my shock are too soft too....if i hit a dip on the freeway fast enough...my tires go all the up to the fender and cuts itself with the fender........time to get new shocks...but i'm tryin to get some tein ss...
pxlds
Aug 25, 2014 09:24 PM
FTNW
May 3, 2011 02:53 AM
D C 2
May 17, 2009 01:34 PM
RedLight_Si
Jun 4, 2004 06:31 AM
vehic_illu
Aug 13, 2003 09:29 AM
