integras at the dyno
Old Feb 11, 2010 | 11:39 AM
green_eg_hatch's Avatar
Default integras at the dyno
My cars at the shop now getting dnyoed ive got a fully build gsr n to be honest im paranoid about valve clearance in vtec im hopeing for the best but it starts up with no problem so out of vtec theres no issue that i can hear but i can only wait n find out.
my set up is
Supertech flat valves
Super tech dual springs
Supertech TI retainers
new valve locks
honda head gasket
12.5;1 pistons
eagle rods acl bearings
and Skunk 2 pro1 cams
hondata s200
wish me luck.
ill let u know if it survives and what it makes.
Old Feb 11, 2010 | 12:02 PM
Lortt's Avatar
Default Re: INTEGRAS AT THE DYNO!!!
Right on, good luck! I'm curious to see what it makes, what header/exhaust and intake are on it?
Old Feb 11, 2010 | 12:53 PM
RedLiningFem00's Avatar
GoodLuck !!
Old Feb 11, 2010 | 01:56 PM
njmad's Avatar
Good luck. like the set up
Old Feb 11, 2010 | 05:35 PM
wunfstgsr's Avatar
Loved
Community Favorite
As long as the heads torqued right and the valve lash is set and its still the same as the stock cams you should be good also if the valve lash was not set to spec that's gonna be a big issue going into vtec. i had the same setup on a 11:6 comp with hytec big tube header and bc spec 3 catback and aem 3'' cai, rc 310cc hondata s100 made 216hp!
Old Feb 11, 2010 | 07:55 PM
made a disapointing 196. the tuner is an excellent tuner but he said i did only 196 hp was because i hve stock bore pistons with such a big cam. so now im saving for a block
Old Feb 11, 2010 | 08:10 PM
omiehomie's Avatar
196 is not disappointing man stock itr motors make around 170-180 ish. stop the negativity and put a bad *** final drive in your transmission and call it a day
Old Feb 11, 2010 | 09:03 PM
im gunna be buyiong another block soon anyways and doing the same set up just the blocks sleved and will have 85mm pistons gunna be a ls bottom end. what are the pros and cons of that going from gsr to bore'd ls vtec. thanks
Old Feb 12, 2010 | 06:06 AM
Turbodude06's Avatar
196 is not bad... First off what Header, Exhaust, any test pipes/cats, and Intake are u using?????? Those play a huge roll too.....
Old Feb 12, 2010 | 06:10 AM
GagnarTheUnruly's Avatar
What type of dyno? Like Lortt said, what I/H/E? Those make a big difference.
Old Feb 12, 2010 | 07:04 AM
Schister66's Avatar
Man U FTW
Call it ignorance on my part, but i don't understand why you would spend all this money, time and effort to go NA and make less power than a stock block turbo setup. Honestly, with what i assume you've spent (and plan to spend with the built/sleeved setup), you could EASILY put down 450-500whp on a boosted setup. Just a thought...i come from a different world of Honda tuning . Good luck with whatever you decide
Old Feb 12, 2010 | 07:05 AM
OH_1fstgsr's Avatar
So your tuner says a 1.8ltr with 12.5:1 compression is not as good as a 85x89 built block. It was very nice of him to state the obvious.
Like many above have mentioned your Intake manifold, Intake piping, Header and exhaust are very important to get the most out of your set-up.
What size injectors are you using? Did you max them out?
Since you mentioned GSR I will assume you are not using the GSR manifold at least.
Old Feb 12, 2010 | 10:25 AM
K Seriese is the Way to go
But, For a B the Numbers arent that Bad... goodluck
Old Feb 12, 2010 | 10:52 AM
94-TEGGY's Avatar
196 aint bad...but u can push put over 300 on a stock gsr turbo..
Old Feb 12, 2010 | 11:14 AM
Yeah but N/A ~= turbo and there's no point in comparing. There's a big pwer range any particular car with any particular cams and pistons will make, and a lot depends on the type of dyno used, the tune, and the type of other mods like I/H/E. Whether 196 is 'good' or 'bad' depends on how all those factors line up.
Old Feb 15, 2010 | 07:51 AM
as far as intake just a short ram. BLox IM 68mm omni TB. Tri-y Headers no cats 440cc injectors.
as far as turbo ill end up spending what i did on a complete turbo kit as i did on all motor. when i know people around here for instance one person i know has the same set up with a bigger piston and he ran 11.90s all day. soo yeaa. im happy witrh set up i have overall
Old Feb 15, 2010 | 07:55 AM
The dyno itself has a big effect on numbers. It's different being on a Mustang dyno vs a Dynajet, and even within one type of dyno different operators and dynos give different results. The proof is in the 1/4 mi.
Old Feb 15, 2010 | 09:31 AM
Schister66's Avatar
Man U FTW
Very true...unless you're like me and have an 11 sec car with a 14 sec driver
Old Feb 15, 2010 | 09:54 AM
gsrtom's Avatar
my set up is
new valve locks
honda head gasket
12.5;1 pistons
hondata s200
maybe its just me but with that setup i would expect more than 196hp. u should be at least at 206whp especially with a s200. what was the fuel/air ratio like? hey just my opinion good luck on future mods
Old Feb 16, 2010 | 06:23 AM
Dynajet 3000 was the dyno i forgot to include. thanks for everyones input
Old Feb 16, 2010 | 11:27 AM
OH_1fstgsr's Avatar
Default Re: integras at they dyno
What is a DynaJet? I think you mean DynoJet.
If the numbers you have posted are the SAE numbers they seem pretty good. With the Pro 1's and the 12.5:1 compression I would have thought a bit more.
You many want to look into replacing the BLOX IM with a Skunk2 Pro or an Edelbrock Performer X. The Blox's IM runners are at an efficient angle for the GSR head.
Old Feb 16, 2010 | 06:33 PM
yes sir haha
Old Feb 25, 2010 | 06:52 PM
Default Re: integras at the dyno
got some tuner 2 cams im having them installed this coming tuesday and then re dynoed wish me luck.
Old Feb 26, 2010 | 03:40 AM
OH_1fstgsr's Avatar
WHAT?
You are changing from Pro1's to Tuner 2's.
Please post the comparison graph. This would be very good information for people trying to understand the differences between these cams.
I think you will see some big changes in the area under the curve.
Old Feb 26, 2010 | 06:57 AM
Yeah, pro1's aren't very good. OP I'll give you $200 for them.
