i need to get my TPS off of my 92 integra. how will i go about doing so? the part where there would be a screw or bolt, it is flat and i have no clue how to get it off.
please and thank you
New User
its also know as the throttle angle sensor and is found on the front/side of the throttle body...im not sure if its bolts or screws..but the chilton manual states that the throttle body must be removed before the TPS sensor can be removed...sorry i dont have a pic, but i'll try to get one for u...
use a hack saw and cut a slit on it, then just use a flathead screw driver to unscrew it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sooo_slow »</TD></TR><TR><TD CLASS="quote">its also know as the throttle angle sensor and is found on the front/side of the throttle body...im not sure if its bolts or screws..but the chilton manual states that the throttle body must be removed before the TPS sensor can be removed...sorry i dont have a pic, but i'll try to get one for u...</TD></TR></TABLE>
i know where it is located. and i am goin to try the hacksaw method, which i have been told has been used for a while and works.
of course it works
i did it to my brothers integra
