Integra Problems DIY Help
Got a used Integra from my buddy because he got in the Jeep game. Has some problems, there's an oil leak and cylinder 4 only has 30psi compression. What could it be, should I rebuild/overhaul or should I just buy different motor?
That's a super vague description, no one could tell if you should overhaul or swap it just from "30 psi". You should do a full leak down test and pin point the cause of your low compression. How many miles are on the block? Depending on its condition, it'd be easier just to start from a more fresh bottom end as getting it back to great running order could require an expensive visit to a machine shop. Anyway, more diagnostics and get a better idea with what's going on. Also check vacuum leaks, dirty intake parts, etc.
Well hey, I literally just got the car and am waiting for it to arrive. All I know about the motors current condition is it can run and drive but it's got an oil leak that's more than likely from the janky cam seal that I can almost peel off, and cyl4 has really low compression. All I need to know is what things I should attempt to find where the compression is being lost and what to look for and you can ASK the information you might need to hear to give such advise, as I'm not telepathic and not yet physically having the car right here to work on, there's only so much I can tell you without asking my friend or waiting until I am free enough to go down there and bring it back which will probably be my next payday so I can really get the ball rolling.
Again, Leak down test. Lots of information on that around honda-tech, team-integra, google, etc. If you're not familiar with them, It's basically a reverse compression test and you use it to determine where the compressed air is escaping from.
Alright I'll check out some information. What do you think about that busted out cam seal, do you think that could be the cause of the car using so much oil and depositing it on the transmission? It's right there on that side, that or the head gasket. Both will be replaced the same time. Prolly getting the Blox billet seal, it looks the best and the others don't seem to be billet and I'm not getting the janky oem seal. My dad instantly assumed cracked head, which I'm fairly sure it's not, but I wasn't aware if the b18b had any typical issues that might be similar to what's afflicting my car. So again if I'm being vague poke me for more details so I can be clear. But I will do the leak down test because it's only running on 3 cylinders atm lolol
lolol
lolol
If you know a cam seal is bad, then that's probably the cause of oil on the transmission. Doubt it's a cracked head, not like it was some high horsepower boosted motor. Best way to diagnose is to pop the hood open when you have the car, turn it on and watch for where the oil is coming. If you say there's some on the tranny then that's a good clue where to look. With 30psi in one of your cylinders, your going to have to pull the head anyway so that'd be great good time to change your seals, gaskets, etc. Just make sure you get quality brands. Also I'd highly recommend getting a copy of the official HELMS manual before you start getting into things. It's the 2000 plus page honda service manual for our cars with detailed write ups on everything. I can't link you to it (rules) but you can find it with a quick google
Your Guide to Buying Quality Aftermarket Maintenance Parts for your Civic:
https://honda-tech.com/forums/honda-...civic-3114911/
If you don't want to take the head off for some reason, I second the leakdown test. That's about your only way to diagnose with the engine assembled.
Looks like a nice ride!
Pop the head off and take a look. Could be a valve, blown head gasket or piston ring. If you are really lucky, it's a bad head gasket and less than $100 to fix. If you are really unlucky, it's a cracked sleeve and you need to buy a new block.
Also, GS trim option didn't start until '98. If it has a sun roof than it's either an LS or SE.
If it is an LS it's all gsd out then because I looked up 97 gsr and a green one that looked just like my teg did stock came up, so it's all very confusing and there's barely any difference so I'm just gonna say it looks good not stock lmao
HoUTX98GSR
Jun 29, 2005 10:01 AM
stealth89hatch
14
Aug 28, 2004 02:36 PM
