Integra no compression
Old Jul 29, 2012 | 10:39 AM
WeaponeG's Avatar
Icon2 Integra no compression
2000 Integra has no spark the flywheel in the distributer spins and there is no spark at all a mechanic my girlfriend knows said when he checked there was no compression. one search on google came up with a guy who said that his cat converter was clogged which fried his distributer cap and cause the car to have no compression. when my car died while driving it it did make a very weird sound that seemed to eminate fromt he exhaust system could the it really be clogged go the car up on jack stands tried to take apart the exhaust but all the bolt/ screws were rusted horribly and could not be removed any suggestions before i pay to have it towed once more to another friends garage where i will definantly have to pay for it to be looked at fixed ect.
Old Jul 29, 2012 | 10:53 AM
JuggerNaut-CTR's Avatar
Default Re: Integra no compression
Seems unlikely the cat would all of a sudden clog and make the car die and have no compression.
No spark...hmmm did you check the coil?
Define no compression? Wheres the comp numbers?
If you couldn't get the nuts and bolts loose, you didnt try hard enough. Saturate in wd-40/pb blaster and use cheater bar?
Old Jul 29, 2012 | 01:36 PM
liftandcut's Avatar
I was told my DA wasn't starting because of compression problems due to the rebuilt head but it turned out it was the main relay.
Posted from Honda-tech.com App for Android
Old Jul 29, 2012 | 04:10 PM
WeaponeG's Avatar
i tried as hard as i could from how far i could actually get the car off the ground and get under it. i am kind of at a loss for what is actually happening with this car any suggestions would be greatly appreciated. the kid who checked the compression said all the numbers were really low and he checked the coil and said it was fine and he checked the fuse and said that was fine
here is the comp numbers (1) 4/35 (2) 3/35 (3) 2/100 (4) 1/35
Old Jul 29, 2012 | 06:42 PM
MDA-integra94's Avatar
When was the timing belt last changed? If the engine died suddenly while driving it most likely broke the timing belt. Check you cam and crank alinement.
MDA
killaj12
Nov 6, 2005 05:03 PM
Nisif
Apr 12, 2005 09:13 AM
kidaniel
Jun 20, 2003 09:21 AM
stupidfast
Oct 20, 2002 03:50 PM
