Integra LS
Old May 13, 2009 | 01:08 PM
SF2000tegra's Avatar
New User
Icon6 Integra LS
Hey everyone i have a 2001 ls integra i would like to know besides boost what i can do to make the ls have more hp? i have put in exaust,header,cold air intake, and msd ignition system. What more can i do to make it have more hp and yes i know put VTECH in it with a different head i just donat hav the money for that right now. Any ideas are appreciated.
Old May 13, 2009 | 01:20 PM
the_big_dl86's Avatar
Default Re: Integra LS
You have to boost or go vtec to make an ls fast. Unless you want to try to build your ls wich will be costly and fruitless.
Old May 13, 2009 | 01:32 PM
DC206R's Avatar
x2
Old May 13, 2009 | 05:43 PM
safedriver's Avatar
I have read about Cowler cams and hondadata tuning. I don't remember which version of cams are the best.
Old May 13, 2009 | 05:53 PM
WDG_729_ITR's Avatar
you could do a motor build...but if you do that you might as well boost it...LS-VTEC is a shakey thing though so if you do make it LS-V make sure it's done right...but yeah, a GSR head would do you some good...and if you don't want to boost it because of a tight budget, check out www.xs-power.com - i've known a few people with turbo kits from there and the only problem i've heard about was the exhaust manifold cracking...but that problem can be solved by either buying a kit with a cast-iron manifold or buying a cast-iron exhaust manifold separately.
Old May 13, 2009 | 06:06 PM
dr.garagetuner's Avatar
"you got to pay to play" there is no real cheap way to gain hp. either do a ls-v or any other b-series build.
Old May 13, 2009 | 06:09 PM
jhammond_82's Avatar
Reject Papi
skunk2 manifold and a t3/t4 60 trim oughta do the trick!
Old May 13, 2009 | 06:42 PM
VTEC_PRODUCTION's Avatar
vtech huh? ::que phone pic::
if you want big power for cheap then piece together a nitrous kit.
Old May 13, 2009 | 06:51 PM
Reject Papi
that will work too!
Old May 13, 2009 | 07:03 PM
CPreston's Avatar
here is your options
1. lsvtec
2. all motor ls
3. turbo
4. swap
ls vtec is gonna be your best bet for a daily driver, but if you dont really know anything about building one i would stay stock until you learned a little more.
Old May 13, 2009 | 08:28 PM
vinceg143's Avatar
^ im in this exact situation but my heart is set on boost but iv considered all of them
Old May 13, 2009 | 08:46 PM
jdm_bones's Avatar
Seems like your on a budget...so here is what I would do, crower 403's or 404's cams...PR3 or P30 pistons to bump up your compression, and a B16 tranny out of a 2000 Civic SI...Then get it tuned...I am sure you will be happy then! Good Luck, but to make really good numbers GSR head with P30 pistons, or slap a snail kit with 550 injectors something that is on the smaller side so that your stock LS can boost fast, make sure to keep it at a low boost since you are more then likely going to running on stock internals, and what ever you do, just make sure you tune, that is the key to horse power.
Old May 13, 2009 | 09:33 PM
cristegra09's Avatar
u jus got a hold of sum ctr piston cause i heard they were good with a b16 crankshaft.. n jus ordered sum crower cams..u think them ctr piston will work as well or shuld i get me sum pr3,p30 piston like u posted?
Old May 13, 2009 | 10:27 PM
OoAreyuloO's Avatar
This has been discussed over and over again
1. set your budget (and than some ...for mistakes)
2. Daily or track?
3. power goals?
4. time and situation in your life very crtical
5.research research!!!!!!!!!!!!!!!!!!!!!!!!!
Old May 18, 2009 | 03:50 AM
DC-T2NV's Avatar
New User
turbo is the way to go !
Old May 18, 2009 | 03:56 AM
The way I see it...take the time to save money to get quality parts (for boosting, etc.) and do it right the first time...rather than being impatient and slapping something together that won't run right, and will end up prolonging your desired gains just as long anyway.
Old May 18, 2009 | 06:26 PM
the most power you can get for your money dollar for dollar is piecing together your own nitrous kit. IM TELLING YOU! all motor is wayyyy to expensive and you wont get near as much power. turbo will cost much more since you will always want to up the boost and with that you have to spend money on more parts.
i am right. there is no other way.
Old May 18, 2009 | 07:05 PM
Lucman's Avatar
Not trying to hijack your thread but I've being meaning to ask the same Q for my 95 integra ls thats all stock no boost no nothing. What would be a good budget to do this?
"This has been discussed over and over again"
1.What would be a good budget to do this?
2. would be daily driving
3. just enough
4. getting better
5.On it
Old May 18, 2009 | 07:25 PM
Reject Papi
i'd say $2000 would be a great start for any build. especially if you shop around in the marketplace for parts. i've seen complete turbo kits go for 700-1000 bucks. that leaves you with more than enough money for a tune, and other optional parts you desire. but, i wouldn't ask about the budget, rather what kind of horsepower you want? that is the more important question. then you can know yourself if it is reasonable or not.
Old May 18, 2009 | 07:38 PM
Lucman's Avatar
I know it is more important what kind oh Hp one wants, but me, I just want my car to be a lil bit faster than it is right now that is it. Im not gonna race it nor turn it into a show car.
Old May 18, 2009 | 07:41 PM
Reject Papi
t3/t4 60 trim, 440cc injectors, skunk2 manifold/ and tb, a good tune at 10 psi should get you past the 250 mark. and if you shop around, i'm sure you can get the parts for under a grand.
Old May 18, 2009 | 07:54 PM
Lucman's Avatar
Thanks man, just did a quick search and you're right, I cold get everything for under 1g how hard/time consuming would be to do all the work myself?
Old May 18, 2009 | 08:34 PM
Well, i'm sure this is your first time...so expect it to take a while, and it expect to run into problems. Luckily, somebody made a step-by-step which I will provide you the link with now.
https://honda-tech.com/forums/forced-induction-16/complete-how-turbocharge-your-honda-rep-ing-hypnotik-speed-1263795/
Old May 18, 2009 | 10:38 PM
DC206R's Avatar
have somebody that has experience with it. so much easier.
Old May 19, 2009 | 08:03 AM
hondatadude's Avatar
New User
what you can do is save up like 700 bucks hit up craigslist and buy you a cheap turbo setup and run it till it detonates lol
