integra HID
Old Jul 18, 2005 | 07:12 AM
ek4 coupe's Avatar
Default integra HID question
i did a search didnt find exactly what i was looking for. my question is if i buy a complete kit will i have to do anything to modify my stock usdm integra headlight for HIDS. my main concern is will the HID bulb be to long for the stock integra headlight. also if anyone has HIDS on there integra with US headlight please post up pics. thanks
Old Jul 18, 2005 | 07:25 AM
RuskeR's Avatar
I guess it all depends on the HID kit you buy. The bulbs should fit perfectly in the OEM housing. The only thing you've got to figure out is where to mount the ballasts.
Here is a pic of my white GSR (5k), and my girls old GSR (6k). It's the only pic I could find online, and as you can see the exposure was set too high.
Old Jul 18, 2005 | 07:29 AM
RuskeR's Avatar
I haven't done the conversion yet, but you should look into getting HID projectors. I've had my HIDs for 3+ years and haven't had any problems. The projectors on the integra are okay for HIDs, but you'll get a more focused beam pattern if you upgrade to the HID projectors.
I'll eventually do this mod, but all my "extra" money is going into my 240 at the moment.
Old Jul 18, 2005 | 07:43 AM
ek4 coupe's Avatar
Default Re: (RuskeR)
the stock gsr projector will work for now right? will the light be spread all over, or will it be decent? also what temp is a good temp. i like the way audi's look. i dont want anything crazy colored tho. i was thinking maybe 6 or 800k. but i am having my doubt about the 8000k.
Old Jul 18, 2005 | 08:13 AM
acuratuner00's Avatar
4300k is pretty good....it just looks bright white...
Old Jul 18, 2005 | 08:23 AM
ek4 coupe's Avatar
Default Re: (acuratuner00)
what about the 6000k, does that have a small tint of blue? what do the tsx's have or nissan maximas?
Old Jul 18, 2005 | 08:37 AM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: (ek4 coupe)
You only get the real hue of bluish/purple from real HID projectors (with 4300K bulbs---that is the standard Kelvin temperature stock-HID equipped cars come with off the factory). We can't achieve this on the stock Integra projector since it's designed for halogen output.
Get 4300K---you wont be disappointed. They turn blue'r anyways in the course of its lifespan.
If you want to learn more, click HERE
Old Jul 18, 2005 | 08:50 AM
fast95se's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4 coupe &raquo;</TD></TR><TR><TD CLASS="quote">what about the 6000k, does that have a small tint of blue? what do the tsx's have or nissan maximas?</TD></TR></TABLE>
All production cars have either 4100k or 4300k. The differnent color in the Audi's is a result of the optics used in the headlamp assembly, not the capsule.
Old Jul 18, 2005 | 08:58 AM
ek4 coupe's Avatar
Default Re: (fast95se)
ahhh i see now. thanks
Old Jul 18, 2005 | 09:03 AM
RuskeR's Avatar
Anything above 6k is just insane. I've seen someones car that he claimed he had 8k's and I swear it put out as much light as my Silverstars did before I did the HID swap.
I'd stick with 4-5k.
Old Jul 18, 2005 | 10:10 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Anything over 4300K is a waste of money, and I do mean waste, because you usually have to spend more and end up with less light output.
My experience with HID in the stock projectors is that it is crap. With 4300K I had light that was very bright directly in front of the car, where it wasn't really needed, and the light would fall off quickly with increased distance (where I did need it). The beam pattern was not wide at all, the cutoff was fuzzy, and there was no color whatsoever at the cutoff.
OEM HID projectors make a WORLD of difference. Nowadays you can get everything you need to do a retrofit for under $400.
Old Jul 18, 2005 | 11:55 AM
m R g S r's Avatar
Default Re: (PatrickGSR94)
tell em pat. btw...either buy my projectors, for okay output...(e55) or get some new TL, TSX, or s2k projectors. they are awsome.
here are a few pics of mine. and my city lights too
lilo_goki
Feb 14, 2009 11:10 AM
cam003
Lighting
Jan 24, 2008 02:58 PM
iNtoXicaTedSPOON
Nov 6, 2003 09:03 AM
