Integra Cut Off While Driving
Old Apr 18, 2014 | 02:36 PM
EF_Tovi's Avatar
Default Integra Cut Off While Driving
Ok, so today as I was driving my car it cut off on me and threw a code. I pulled to the side and tried starting it again and no luck. Then I turned the key to the "on" position and noticed the fuel pump wasn't priming either. I replaced the fuel pump and tried again and the code was still there, and no prime. So, I went to try a spare main relay I had and same issue, cel and no prime. I got the car towed and tried a second spare I had and same deal. Can anybody help?
Im going to have a buddy bring his integra over and try his relay since I know his works.
Car is a 97 RS with a gsr swap, running an obd2a-obd1 jumper if that helps.
Old Apr 18, 2014 | 03:25 PM
tobe1424's Avatar
Default Re: Integra Cut Off While Driving
is the distributor rotor good? have you check that?
Old Apr 18, 2014 | 03:29 PM
EF_Tovi's Avatar
I forgot to mention fuel isn't getting to the motor at all so I don't think it'll be the rotor.
Old Apr 18, 2014 | 05:11 PM
tobe1424's Avatar
Filter changed recently? Also could be an electrical issue..such as a relay etc
Bolo_PR
Jul 26, 2012 07:47 PM
jv88_dc2
Dec 14, 2011 08:17 PM
guedo148
Mar 20, 2010 05:41 PM
Auby
Oct 1, 2008 12:13 PM
