Integra back up fuse problem
Old Jul 30, 2008 | 08:31 PM
asc's Avatar
asc
Default Integra back up fuse problem
My back up fuse for my 99 integra keeps blowing, knocking out the clock, stereo, and ecu back up memory.
Everytime I come back to my car, the fuse is blown, especially on a hot day. So it seems that it is blowing whenever I am not in the car.
I have tried leaving the stereo disconnected and looking for any shorts in the wiring and it seems good. Could it be my ECU? I have some DINAN ECU which is kind of weird.
Any help will be greatly appreciated, TIA
Old Jul 30, 2008 | 10:43 PM
JDM_CRX_PLEASE's Avatar
maybe you should try getting a stock ECu and then run it for a day and see what happens?
Old Jul 31, 2008 | 11:25 AM
asc's Avatar
asc
I could but that ECU has the tune for the set up I have, thus putting in a stock ECU not a good idea. Any other possibilities?
Old Aug 2, 2008 | 10:32 AM
asc's Avatar
asc
ok I just ordered a 100 pack of 7.5 fuses since I've been spending a good amount for those expensive 5 packs. bump for suggestions
Old Aug 10, 2008 | 04:19 PM
asc's Avatar
asc
Bump
Another thing is that the fuse especially blows when the car is or has been in the sun
Old Aug 13, 2008 | 09:06 PM
ooooooo in the sun.. i dunno what that means but honestly
my fuse blew because i hit a bump and then in my civic it blew because it was hot outside also. so i mean it could be that...
i was at a redlight and my car just shut off, my ecu fuse that is. but it was like 100something degress. could be that!
but hey its good you bought 100 pack bundle, saves you money. sorry i cant help!
Old Aug 13, 2008 | 10:12 PM
asc's Avatar
asc
yeah the fuse goes out when I hit a really hard bump or during WOT since my vtec kicks in so damn hard, haha
Old Aug 14, 2008 | 04:06 PM
asc's Avatar
asc
bump
Old Aug 14, 2008 | 04:59 PM
VerbalVenom's Avatar
Default Re: (asc)
Could be anything. Have you chased the wires with a multimeter? Otherwise you'll just get people giving you shots in the dark with no real answer. With my Caprice, I had 2 ECUs for it. One was an Autozone reman that my dad swapped for me like 5 years ago, and the other was from Ebay. I had switched ECUs because I thought the reman he swapped with my old one wasn't compatible with my Caprice (I had a 9c1 ex sheriff caprice with a 350 instead of a 305). I put the oem ebay ECU in and the car is running fine. One day i'm coming home from work and it just shuts off on me going 45. I was right at my house. From then on it would turn on then turn off. Finally I checked the fuses and found out that my fuel pump fuse was blowing every single time. I swapped ECUs again and ran it like I stole it and not one fuse blown till this day. Basically it can be anything. I thought it was a fuel pump error, but it was actually the ECU...
Old Aug 15, 2008 | 01:04 AM
asc's Avatar
asc
yeah, thanks for the insight. I think I'll buy a multimeter soon. I have suspicion that it may be related to my ECU. Then again, I pulled the fuse box out today and the harness looked really nasty, like a bunch of white gel acid substance, don't know what it's called.
Anyway, what's the best way to clean that type of stuff off plug harnesses? haha
Old Aug 18, 2008 | 02:52 PM
asc's Avatar
asc
asdf
Old Sep 5, 2008 | 03:01 PM
asc's Avatar
asc
Default Re: (asc)
tttt
Old Sep 5, 2008 | 03:10 PM
BoSox46GSr's Avatar
Default Re: (asc)
CRC makes an aerosol spray for that... this has happened to me a few times, once in my da, and like 12 times in my dc. The da was due to a water leak, the dc was due to a bad ground.
Old Sep 10, 2008 | 11:42 AM
asc's Avatar
asc
Default Re: (BoSox46GSr)
thanks for the info.. got some crc electronic cleaner and cleaned it out... but the problem is still there
anyway, where exactly are the grounds for something that is related to the backup fuse (clock, ecu memory, radio)? so far it isn't the clock, ecu, nor the radio because I individually disconnected each and the fuse still blew. any more suggestions will be appreciated, thanks
Old Sep 11, 2008 | 01:14 AM
asc's Avatar
asc
upupupu
Old Sep 14, 2008 | 06:25 PM
asc's Avatar
asc
ok so I finally fixed it, that was one bitchin headache. there was a short somewhere deep behind the dash, where it was unreachable so I almost pulled the dash out just for that but ended up rewiring to avoid such labor.
I can say I am pretty happy this is finally fixed since I have spent days trying to figure it out
Joshb152
Oct 9, 2015 09:10 PM
hondapimp125
Jun 19, 2009 02:18 PM
OpTiX619
May 14, 2005 10:05 PM
