anybody know if there is a plug to cover this hole?
i want to close it off so no water or w/e gets in cause i took out the antenna and base and everything completely
any pics or part #'s would be great or any ideas on how to close it off
Hmmmm, word bro: Google
Try: ebay antenna plug integra
One of the better choices from the top item's list:
https://honda-tech.com/forums/acura-integra-type-r-8/oem-antenna-plug-part-number-2291639/
Have fun
Have fun
nice gg bro ty
I welded that hole shut. No leaks since lol.
yeh when the car goes in body shop for some paint and quarter pannel repair and some deleting/shaving ima have him weld it shut too so there isnt a plug stuck on the side of car, just need it for now cause its about to come out of 2 year indoor storage to go back on the road.
I forgot to mention, I forgot to use weld thru primer for the backside when I welded the new piece in which you must do because it'll rust within a year from the inside. But that shouldnt be a problem if you're getting it professionally done.
heh a buddy and I welded up my wing holes when my car was painted in 2004, and I also forgot to prime and paint the welds on the underside. 7 years later they look pretty rusty if you open the hatch, but it's just surface rust. You can't tell anything from the outside.
why dont you just get the HONDA OEM antenna delete plug
Call them and ask them for a 25mm Grommet. That plugs the hole perfectly, no sealant needed and prevents water leaks. Heres a pic of mine, You can paint it if u want
Quote:
hm sounds like you got lucky. Just as long as its not a structural thing I guess it doesnt matter too much.Originally Posted by PatrickGSR94
Quote:
or you can use this 82871-671-000 GROMMET (25MM) thats what i used and i believe its from a tsx or something but it fits perfectly ive been running mine for years no prob. and its only like 2.50 so whichever is cheaper thats what id buyOriginally Posted by sebTeggy
91615-SA5-000
