integra
Used to happen to me .. take out your tail lights and make sure that ... lol i forget what its called.. the Rubber gasket ? Is nice and tight the whole way around on the inside ... I fixed this on mine and the water hasnt returned .. but now my tail lights fog alittle every once in awhile.
So id check out ur tail lights
Also i think ive heard ppl say about the antenna area leaking
Also check your sunroof drain tubes, if you have a sunroof. Sometimes the drain tubes come loose or get clogged. To access them remove the rear panels and you should see tubes.
Ali
Ali
Pull the trunk interior and strategically line the trunk with paper towels to trace the source of the leak. The most common culprit is the taillight gasket. I have seen wheel wells leak as well.
