installing tachometer but doesnt work
so today i wired everything to what was sed..
red - to radio wire.. 12v
white- illumination
green - RPM input
black - to whatever is metal..
tell me if tahts correct?
i couldnt get it to light up or to work .. please help me someone .. 4 wires were cut off since my car is a 4 cylinder
Whats wrong with this setup?!
white- illumination
green - RPM input
red needs to go to ignition wire?
i been searching up so much that it says it need to go 12v
does white go to the one in the gauge cluster?
Your ignition wire is a 12v switch, and yeah white could go into gauge cluster, connecting to one of the wires for a bulb.
read this https://honda-tech.com/zerothread?id=949918
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dungsta »</TD></TR><TR><TD CLASS="quote">my white wire went to the blue with grey dots in the gauge cluster..</TD></TR></TABLE>
That's your tach signal wire
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dungsta »</TD></TR><TR><TD CLASS="quote">okay i finally fixed it and it works.. how do i adjust it? do i hold the red button then move the dial up? </TD></TR></TABLE>
Turn you key on but don't start, move the red button to the RPM you desire. Turn off the car and start your car and test it out.
mike1114
Apr 19, 2006 06:39 PM
Vtakkk
Mar 3, 2006 03:35 PM
