Installing Steering Wheel
Old Dec 16, 2008 | 04:50 AM
kumar*'s Avatar
Default Installing Steering Wheel
I recieved my SiR-G steering wheel the other day, and I installed it. At first I didnt notice that I had the steering wheel off, so it was crooked to the right while driving. I adjusted the steering wheel about 5-6 times, but I still cannot get it to sit straight while driving straight! I know there is the crown in the road, but I still cannot get the wheel to be straight..
This is the first time this is happened to me, and IDK what else to do. Do the JDM steering wheels have different splines for the hub??
Or, is there any tips/tricks/suggestions any of you have while installing a steering wheel..?
Thanks!
Old Dec 16, 2008 | 04:53 AM
weavertime1's Avatar
When you take off the steering wheel, move it just slightly before you put it back on. If all else fails, get an alignment. It might be a good idea anyway if you haven't had one recently. Good luck!
Old Dec 16, 2008 | 04:55 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
When you say you adjusted the wheel several times, do you mean you just barely pulled it off the shaft, turned it slightly by a few teeth on the splined shaft, and then put it back on?
Old Dec 16, 2008 | 05:14 AM
kumar*'s Avatar
Yeah, you are correct.
Old Dec 17, 2008 | 09:10 AM
civicdreamin's Avatar
i agree.. get an alignment
Old Dec 21, 2008 | 12:26 PM
kumar*'s Avatar
Default Re: Installing Steering Wheel
alright, i'll see what happens when I get an alignment.
Although the car doesnt tend to swerve to one side when I let it go.
Old Dec 23, 2008 | 10:32 AM
Hippslsvtec18's Avatar
when they do the alignment, they will fix your steering wheel, it will end up straight, just let them know its off, i used to work at a shop that did alignments, and this was a common problem with aftermarket steering wheel installs..
Popkorn
Sep 9, 2005 05:20 AM
