Installing SRI, simple question....
Old May 26, 2004 | 09:26 PM
escape2me's Avatar
Default Installing SRI, simple question....
I should have trouble with the install, all I wanna know is why I have heard that you need to reset your computer too??? Probably a dumb question but I couldn't find anything while searching so....
Old May 26, 2004 | 09:46 PM
purplegsr's Avatar
Default Re: Installing SRI, simple question.... (97 GSR)
It is necessary for the computer to be reset so that it can adjust more quickly to the modification you just made. The air flow into the engine will be changed by the different intake, so your computer will need to 'learn' the new setup. It's easy to do it, unplug the ECU or disconnect your battery for about 10 minutes. Then, start the car, and leave it idling for another 10 minutes - don't touch anything.
Also, your car will eventually 'learn' your mods itself, you can just leave it and over a few weeks it will adjust to the mods to optimize performance as much as it can.
Old May 26, 2004 | 09:53 PM
EV1L SI's Avatar
SCAM ARTIST
Default Re: Installing SRI, simple question.... (purplegsr)
what purplegsr is pretty much correct. You need to reset your ECU so it knows that you made changes to your motor. pretty simple.
Old May 26, 2004 | 10:32 PM
escape2me's Avatar
Default Re: Installing SRI, simple question.... (GSR Coupe)
Oh, wow. And I thought I was gonna get flamed for askin'.... Thanks a lot for the help
Should I disconnect the battery before or after the install???
Old May 26, 2004 | 10:37 PM
purplegsr's Avatar
after is fine, you can start your car after you do it, to make sure everything is attached and working. You just want to disconnect the ECU later on to make it learn, or you can not reset it and just let it learn by itself. If you are making a trip to the dyno or something, you will want to reset it to get the optimal effect.
Old May 27, 2004 | 03:13 PM
escape2me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr &raquo;</TD></TR><TR><TD CLASS="quote">after is fine, you can start your car after you do it, to make sure everything is attached and working. You just want to disconnect the ECU later on to make it learn, or you can not reset it and just let it learn by itself. If you are making a trip to the dyno or something, you will want to reset it to get the optimal effect.</TD></TR></TABLE>
broken94
May 16, 2008 02:58 PM
melvin
Aug 18, 2005 07:27 PM
3rdgencrx
Honda S2000
13
May 20, 2005 10:13 AM
escape2me
Jun 2, 2004 09:36 PM
