Installing new main harness...
Old Mar 2, 2004 | 07:25 PM
GotGSR's Avatar
Default Installing new main harness...
OK I got a couple questions concerning the main wiring harness and replacing it. Mines currently fizzucked up to hell. Missing alot of different elements. a replacement harness is just the way to go. So...
A) How hard is this to do exactly? The harness is OBD1 for a GSR. I've talked to a couple people, they both say it's not hard, its just very time consuming.
B) If someone can clarify... There's an engine harness (all the wiring in the engine bay) That connects to the Main harness, which runs to the ECU. The main harness also runs to all the interior eletrical stuff, (tail lamps, ABS, doors, etc.)
Thanks ahead for any input. Any info that you know would be greatly appreciated.
Old Mar 2, 2004 | 07:33 PM
Kendall's Avatar
Like you were told, it's not all that hard, it's just really time consuming. Be sure that you note exactly how the harness was routed to prevent any issues with wire lengths.
Old Mar 2, 2004 | 09:35 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (Kendall)
It's an "easy" job, but it's a pain in the *** and time consuming. The second part of your question....no, it doesn't go to the doors and all the lights and whatnot.
It's just from the ECU to the main engine components such as the injector rail, alternator, etc. As Kendall said, take note as to how it is routed. If it's not perfect, you'll find some plugs won't reach and you'll have to start over.
Good luck getting all all that underneath the intake manifold.
Old Mar 3, 2004 | 08:12 PM
GotGSR's Avatar
Default Re: (shamoo)
Wait now what about ABS and lighting and what not? How does that get connected to the ECU if not through the main harness?
Modified by GotGSR at 10:04 PM 3/3/2004
Old Mar 3, 2004 | 08:19 PM
shamoo's Avatar
Default Re: (GotGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GotGSR &raquo;</TD></TR><TR><TD CLASS="quote">Wait now what about ABS and lighting and what not? How does that get connected to the ECU if not through the main harness?</TD></TR></TABLE>
That's all internal in the dash and within the actual car. The ABS unit is on the passenger side in front of the rear speaker (if it's a coupe). It's where the rear passenger door would be.
All the lighting wires and "unimportant" stuff comes from another harness.
Old Mar 7, 2004 | 10:55 PM
soquickls's Avatar
i know its not really on topic but have to ask didnt want to post a topic bout it ok heres the question i have a 96 integra lsvtec b16 head with ls wire harness and ls distributor...a guy told me i was losing horsepower with out the proper b16 distributor. well i was wondering if the b16 distibrutor would just connect to the ls harness? they are both obd 2 99 si head 96 ls wire harness? thanks
$MIKE$
Jun 10, 2014 12:47 AM
arc_55
Welding / Fabrication
Mar 23, 2008 12:09 AM
Rusty Shackleferd
Jan 25, 2005 11:28 AM
D3U1LT
Jan 24, 2005 10:47 AM
