Install DSM Injectors
This f*cking integra forum is becoming more worthless by the day....now its just cluttered with the same crap over and over with no hard tech stuff...for future reference, try the drag racing or forced induction forums...
now before i tell you, how are you controlling these injectors? you can't just put them in for a couple of reasons...1) you have to be able to control them, just flowing more fuel will not make power 2) you need a resistor box, PM "sonny" he can get you one with wiring instructions. the reason why you need this is because the stock injectors are saturated and the dsm are peak and hold...two different types of injectors. WHy are you upgrading? Do you have hondata? VAFC hack? turbo?
Now for the installation. In terms of parts, you need OBD1 clips (which you have) and 96+ SOHC civic injector spacers (which sit in the manifold). Use the stock O rings from the DSMs. Now, on the part of the injector that plugs in, you will see a ridge inside the plug. grind that away...much like you would if you were doing the 9005 light conversion. With that done, use the parts and just put it all together.
Good luck.
Good luck.
First of all YOUR WELCOME. Get in the habit of thanking people when they give you information...
Second of all, go to hondata.com and they have a wiring diagram.
Black R
Jan 2, 2005 06:31 PM
