Injectors?
When your stock injectors can't supply enough fuel, or require a significant pressure rise to do so.
For an all-motor setup, I think 290's (prelude) are generally sufficient if stock Integra injectors won't suffice. Some opt for 310's.
[EDIT] You ARE doing an all-motor setup, right? I just realized you mentioned turbo.. if you install a turbo then yes you definitely should install bigger injectors.
[Modified by Cow, 10:03 PM 12/7/2002]
anytime you go turbo... its always better to get bigger injectors. 310s at least. any application putting out more than 200+ would benefit from bigger injectors... as long as its tuned or tuned in some way.
B_1_8_hatch
Sep 12, 2003 11:23 AM
